Question about HTC Tilt 8900 Smartphone
My HTC 8900 is just under two years old. On full battery, it dies in the middle of all calls. It will only function during phone use on the charger. It's fine during texting and I have tried clearing the storage.
    Problem Solver:
  • 4 Answers
Eventually the batteries will no longer hold a charge and need to be replaced. Here is a link to the battery for your phone...http://www.amazon.com/2800mAh-Extended-Battery-Kaiser100-T-Mobile/dp/B001AGLIJ0
Posted on Oct 13, 2010
I need to charge my htc wildfire s phone battery it won't charge it's not the battery or charger it's the socket
Probably you will have to buy an external battery charger that will charge the type of battery the HTC Wildfire is using. But if you upgraded to another HTC phone, maybe the new one is using the same battery as the Wildfire and then you can charge the old battery in the new phone and then use it in the old phone to transfer your contacts to the new phone.
Jul 31, 2014 | HTC Cell Phones
My device batery ran low and turned off and wont turn back on what do I do
Try a new battery if you have one available.
-If you don't, and have friend with same phone or similar, check to see if the batteries are the same
-Try a different charger. (sometimes your charger head becomes loose and useless)
-Wiggle Cable - see if creates light to come on or off.
-If under year warrenty - call cell provider, usually will replace your phone under manufactor's one year warrenty - ex. easier to deal with getting a replacement from Verizon rather than straight thru Motorola
Apr 08, 2011 | HTC EVO 4G Smartphone
BB Curve 8900 cant turn on!!! Pls help
Try to Re-Charge your phone with electrical charger for 6 hr,
then try it
Jul 14, 2010 | RIM Computers & Internet
I have an HTC Tilt 8900 Smartphone, but I cannot access my phone because I forgot the password. How can I access my phone, if I forgot the password to unlock it?
you need to do a full software replacement ...... www.htc.com download the rom ..remove sim card and Micro sd if you have one ...connect to active sync and click on the file you downloaded then just follow the instructions
May 24, 2010 | HTC Tilt 8900 Smartphone
My tilt 8925 wont charge the battery anymore, I've had it appox 1 year. the phone reacts to the charger being pluged in but won't convert over to charging mode
If it will turn on a little, tap the icon for the battery in the upper right hand corner of your main screen. This will bring up a "system status" screen. Tap the icon of the battery there also. It will then pull up a tabbed screen. Under the "battery" tab, make sure that the check box next to "when device is turned on, do not charge the battery when connecting to the PC" is UNCHECKED. Then try plugging it into a USB port and see if it will charge or sync. I hope this helps!
Jun 29, 2009 | HTC Tilt 8900 Smartphone
HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
Jun 05, 2008 | HTC S710 Smartphone
Htc tilt phone
You have to get the new driver update to fix this problem, I had it for a couple of times until I got the update, now I am looking to sync my phone with the new driver.
May 26, 2008 | HTC Tilt 8900 Smartphone
Stops while talking
Hi folks with aging JAMS. My JAM is still dying (complete shutoff) using phone. I wish it would just lose the phone signal but my unit shuts off completely during phone calls. I can have 80% charge. I spoke with a friend that mentioned on his cell phone (different manufacturer) that although his battery will show a full charge or less, the time it takes for the charge to go down is ridiculously fast once the battery is old. He watches his phone lose a charge in under an hour though it charges to full.
I wish IMATE would make some formal post regarding when to get a new battery and what symptoms are possible. I'm a bit hesitant to invest in batterys if the issue is hardware. I use the unit alot--as a PDA, a phone, etc. It gets jostled about so maybe something is lose inside, though I doubt it.
I purchased a cheap phone charger so in the car I'm recharging and at work I just keep a cheap USB to plug charger. I reserve the phone when I'm out. This is not really optimal for cell phone use but it's a behavioral fix. I figure I should be looking at a new device (despite high prices) soon.
I did a full discharge/charge cycle or two or three but only noted short term benefit. At some point the quirky behavior returned and off went the PDA cell with the 80% charge. I see dots of us around the net. Again my Jam is probably 3 years old this March.
Oct 28, 2007 | i-mate JAM Pocket PC
HTC Tilt 8900 Smartphone Logo
64 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
