I am not sure what you are describing here, if the prints are left justified this is just a setting. If you are saying that the print doesn't come out on the right side there could be several problems. Please find a qualified engineer to assist
I assume by double tags you mean 2 labels across the roll. You need to tell your software that the roll is 2 across. If using the software that comes with the printer, Zebra designer. Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
you can adjust this in the template file for your price tags. how did you create your basic price tag label? in the zebra label creator? if so, make the adjustment there. if you have a .ejf file for your price tag label, you should be able to open it in notepad and add the height in pixel dots with the "q" or "Q" command from the EPL programming handbook. This can be a little tricky, but with some trial and error, you can get it.
DID YOU CLEAN THE PRINT HEAD AND BRY IT GOOD, CHECK THE SOFTWARE.
MAKE SURE THE MATTERAIL IS THE SAME FOR EACH TAG, DIFFERANT TYPE OF MATERAIL WILL GIVE DIFFERENT TYPE OF PRINT AND THE FINAL PRODUCE WILL BE TOTALY DIFFERENT.
SEE IF THE PRINT HEADS HAVE THE SAME CLEAR-INES, SEE IF THE HEADS HAVE APART THAT CAN MAKE THE PRINT A BETTER PICTURE OR BETTER QUILITY OF PRINT.
SEE IT THE PRINT HEAD HAS ANY TYPE OF HEAD ADJUSTMENT, REQUEST A SERVICE MANUAL FOR THIS TYPE OF ADJUSTMENT AND YOU WILL NEED SOME FILLER GIUDGES TO MAKE THAT SDJUSTMENT THE SAME ONES YOU USED TO FIX THE OLD CAR WITH THE FLAT SILER ONES
Verify that the ribbon fits into position, back and forth. You can also calibrate the label by pressing the button while powering up the printer and release the button.
