Question about Stanley Bostitch PN100 Palm Nailer
Spring on the finish nailer nose for the Bostitch PN100K palm nailer broke. where can I find either the spring or the finish nose
  • Stanley Master
  • 7,733 Answers
Try here ->link.
Posted on Oct 14, 2010
  • 1 more comment
  • brucegreen35 Oct 14, 2010
    That site had no springs nor the entire nose. Even inputed the part number in the search box, but it showed no results
  • Doctor PC
    Doctor PC Oct 14, 2010
    Try herehttp://www.toolpartsdirect.com/cgi-bin/s...
    Nope, nothing there. I can find the schematics for the entire tool, and also for the nose piece. When I search for the part number, every site I go to returns no results for the spring. I have also yet to find any place to buy the entire nose piece.
Won't drive the nails. The hammer slides over the top of the nail bending the nail and jaming the gun
odd, but may be nose part loose and or the magazine too loose, is your driver bent?
the magazine and the nose part meet check under the cover and make sure all the 3mm hex bolts are secure. should be 4 if im not mistaken.
Feb 15, 2016 | Stanley Bostitch SB1664FN 16 Gauge...
I bought my nail gun secondhand and can't find model number to order some nails?
Go to www.toolpartsdirect.com and click on brand name of the tool. From the catagories that follow, select the icon that most resembles your tool (pinner, finish nailer, coil nailer, framing nailer etc. ). Then click on the defferent model numbers to id your tool. Usually the model number is stamped on the body just above the nose. Not very visible because after stamping the number, it is painted bostitch yellow. You can also send photo of the gun to www.alco1@sbcglobal.net and I will ID the gun. Good luck
Sep 25, 2011 | Stanley Bostitch Nail Gun
Nail cleats are not exiting when the mallet hits on my Bostitch MFN-201. The spring mechanism appears quite loose; you can push it down or in very easily by hand.
That is most likely what needs to be replaced as that is the return spring. If it is weak it may not be allowing the driver to go back up far enough to let the next cleat load into the nose. Here is the parts diagram. Bostitch (Stanley Tool Works) just merged with DeWalt so you can get the part from either company now or a dealer of either company.
http://servicenet.dewalt.com/Products/Detail/MFN-201
Jul 23, 2011 | Stanley Bostitch Mfn201 Manual Hardwood...
Bostitch Rn46-1 Nail feed keeps coming dislodged when firing gun
The feeder will dislodge if the feed paw spring is weak or missing. Replace with new spring to keep the feeder paw in place. Visual test with good feed spring. Remove nails and open side door. Fire gun rapidly against hard rubber or coiled air hose. The feeder should move back and fourth in time with the piston/driver. If the feeder seems to move in slow motion compared to the driver, check feeder piston orings and feeder piston spring. If both feeder piston orings and spring are in good condition, then check air passage to feeder piston chamber for obstruction. Sometimes debris will lodge in white oring where body mates to nose of gun. Good luck
Jan 14, 2011 | Stanley Bostitch Rn461 Gun Coil Roofing...
FixYa is a Fraud, just brings up empty useless ****
Ask questions you want answered, don't just make dumb comments
Jan 09, 2011 | Stanley Bostitch PN100K Impact Nailer Kit
Nail is jammed in my Bostitch power finish nailer and partially sticking out. When pull on nail with pliers, it won't come out.
Remove driver guide nose peice, should be a couple of alan screws, remove nail, check driver to make sure it is not bent, re assemble. Make sure you are using the correct Nails!
Aug 27, 2010 | Stanley Bostitch N88rh Framing Nailer...
I have a Stanley Bostitch finish nailer n60fn its leaking air from the trigger and housing.Is this something that I can rebuild and if so where can I get the information on how to rebuild it?
The fix it replace the trigger valve. It is a 5 minute job and seems to be a pretty common problem. Bad news is they seem to run about $30. I believe the bostitch # is TVA6
Apr 04, 2010 | Craftsman Nailer Kit, Palm Air Driver
Safety B
Sounds as if you have a small Bostitch nailer/stapler. Bostitch lables its safety mech parts as Safety A for the part that actually contacts the work and Safety B for the part that contacts the trigger. Go to www.Bostitch.com and look for diagram of your gun. These two parts fit snuggly just behind the outer-most guide/nose. Safety b sits on top of safety a. There is usually a thumb adjustment and a spring between the two parts. The spring is usually installed on top of safety a and below the adjustment knob. enjoy
Nov 23, 2008 | Air Tools & Compressors
Stanley Bostitch PN100 Palm Nailer Logo
367 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
