Question about HP LaserJet 3055 All-In-One Printer
HP All-in-One 3055 "Scanning Error 6" What can we do?
  • 315 Answers
Hi Cherylanne, Give this a try: Scanner Error 6 Turn off then on
1. Clean Glass Scanner Bed.
  • If the glass scanner bed is too dirty or smeared with fingerprints and such, you may get this error. It will not clear itself simply by turning off and on the printer such as the message suggests. Even a build up of dust can cause this. It is triggering a reaction caused by a sensor in the scanner. If you clean it good and then power cycle it, the problem should go away. THIS PROCEDURE FIXED THE PROBLEM FOR THE AUTHOR.
2. Try the NVRAM INITZ reset procedure. REF
  • switch off the printer, then remove all cables connecting to the printer but just the power cable.
  • then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
  • continue holding the button till you see "perment storage init" displayed and releas the button.
  • then at a given point of time the printer will ask you to change laguage,time,date etc.
3. Remove paper scrap or dust obstructing scanner or sensor. REF
4. Clean sensor / remove the glass and clean the bulb and mirrors. REF
  • turn off power
  • remove ADF and inspect blew out any dust
  • unclipped control panel cover and removed top platen cover 4 torx screws
  • inspected and dusted (blew out) the scanner
  • put platen cover back again and placed 5 sheets new paper over right side (where scanner is) and turned on came up happy
  • turned off reinstalled ADF (cleaned the white surface first) turned on again
5. Scanner Bulb is not getting to the alignment area.
Information found @
http://wiki.robotz.com/index.php/HP_LaserJet_3055
Regards
Mike
Posted on Oct 12, 2010
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
Error 6 & 8
Error 6 is a scanner failure I believe and no 8 is an software installation error http://h30434.www3.hp.com/t5/Scanning-Faxing-and-Copying/Error-8-8-0-0/td-p/202248 please have a look at the post on the bottom of this page.
Mar 17, 2012 | HP LaserJet 3055 All-In-One Printer
Says "scanner error 6 turn
If power cycling the printer didn't get rid of the "scanner error 6", you are going to have to get the AIO scanning assembly replaced. That is the top of the printer, the flat bed scanning assembly.
Apr 16, 2011 | HP LaserJet 3055 All-In-One Printer
"Automatic Scanning could not be completed."
you haven't a problem in your cable, you have a problem in he printer.
refer to your user manual
May 07, 2010 | HP LaserJet 3055 All-In-One Printer
Laser jet 3055 scanner error 6
Generally, Error 6 is a failure of one of the PCA boards and the unit requires service.
Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
182 people viewed this question
Seeker5211
Seeker5211
