Question about Duo Fast Duofast Cn350 Cn350b Sh Nailer O Ring Rebuild Kit
Looking for instructions to rebuild a duo fast cn350
Duo fast leaking oil
putting to much oil into tool ( it just takes a few drops a day) or cap/ nose has loose screws
May 05, 2012 | Duo Fast Duofast Cn325 Cn350 Nailer Oring...
Repair duo fast nail gun
Duo-Fat is now owned by ITW which also owns Paslode. The DF350S is basically the same thing as the F-350S Paslode. Go to Duo-Fast's website to locate a servicing dealer nearest to you.
http://www.itwindfast.com/buy.cfm
Feb 16, 2012 | Duo Fast DuoFast DF350S 20? Round Head...
What degree nails should be used for a duo fast Cn 350 B nail gun?
The CN350 uses a 20 degree, full round head, plastic collated nails.
Jul 21, 2011 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I have a duo-fast n350 ant it sets the nail to deep . any adjustment
Three methods to adjust how deep nail will set. On nose of gun is fine adjustment, move contact claw by backing off screw and moving up/down. Replacing the lower bumper with new part will prevent driver from driving too deep into work (new bumper is more firm and probably thicker). Finally, adjust piston on driver blade by turning then re-apply lock tite (adjust piston head closer to work). Good luck
Feb 20, 2011 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I have a duo fast CN 350 nailer and it works ok but it don't seem to let the driver blade to come up high enough to get on nail head
You will need to pull the top off to get to it to check it out, If the drive pin is bolted on, make sure the bolt didn't loosen up, most are one piece, welded on, If you don't find anything in there preventing it from coming up, I would grind off the tip, nice and square and flat, then put it back together. I have a feeling you will find a piece of white plastic holding the piston down, part of the head there, It will need to be replaced. Check it out, hope this helps.
Dec 29, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I need a trigger diaphram for duofast 880 where can i get one
I order parts from www.toolpartsdirect.com , however I also make some of those parts and you can also. I keep a variety of plastic and rubber sheets to make replacement parts. You can also use fuel pump diaphram material. Be creative or just order the parts from web above. Good luck
Nov 16, 2010 | Duo Fast Duofast Cn325 Cn350 Nailer Oring...
Blowing air through trigger area. Need rebuild kit? Longer version...started blowing air out of small hole in left side of casing. Leaked oil out of there as well but still worked fine. This has been...
If the trigger still works to fire the single shot, then the o-ring kit should be sufficient. If the trigger area continues to leak air, then the trigger should be replaced as well. Keep the gun well lubricated as well.
Dan
Oct 02, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I have a duo fast cn350b that misfires, the piston seems not to retract back into the chamber
I have the CN350 - not sure how it and the 350B differ.
There are several possibilities that I've experienced.
Nails other than Duofast. Causes a jam that does not allow the driver to return.
Not enough oil.
Not enough air.
Worn O rings.
Sep 09, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
DUOFAST REBUILD KIT SUPPLIER
you might try Nailgundepot.com for parts
Dec 07, 2009 | Air Tools & Compressors
Duo Fast Duofast Cn350 Cn350b Sh Nailer O Ring Rebuild Kit Logo
177 people viewed this question
Top Duo Fast Air Tools & Compressors Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Ted Maxwell
Are you a Duo Fast Air Tool and Compressor Expert? Answer questions, earn points and help others
