Question about Dryers
Drum not spinning - Dryers
  • 3 Answers
Might be a bering out
Posted on Oct 12, 2010
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin ยท Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
Why does dryer spin with door open?
Hi Mandy,
The fact that the light bulb is out *and* the drum continues to spin when the door is opened - all point to a faulty door switch.
This switch tells the machine the "status" of the door position. When the door is open, it turns on the light *and* stops / prevents the drum from starting. When closed, the light is shut off *and* the drum is permitted to spin. You should have the switch serviced as if a wire came loose it adds a potential shock hazard - in addition to the safety issue of placing hands into a spinning drum.
Jul 10, 2013 | Dryers
Dryer will only spin with small load
You need to replace the belt that will solve all your problems.
Oct 17, 2012 | Dryers
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but...
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
May 08, 2011 | Kenmore 22422 Top Load Washer
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
Apr 18, 2010 | LG WM-1832C Front Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Dryers Logo
Top Dryers Experts
