Question about Refrigerators
I HAVE A GALAXY CONPACT REF. AND IT DOSEN'T COOL LIKE IT SHOULD. I COULD 4 TIMES AND THEY CAME OUT TO REPLACE EVERYTHING NOW THEY ARE SAYING THAT IT IS JUST A COOLER BUT I BOUGHT IT THINKING IT WAS A REFREG.
    Genius:
  • 1,622 Answers
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Take care in solving the problem.....
Posted on Oct 13, 2010
I bought a used Samsung Galaxy Tab 4 (8.0) running on AAA Automobile Club towing system on it, I want its original android system back into it, where can I find that specific download? A link please!
Try a Hard Reset which clears everything off it and installs Android new. There are no Android download links.
  • Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8 ... www.verizonwireless.com > Samsung Galaxy Tab 4 (8.0) Before performing a hard reset, ... Home > Support > Samsung > Samsung Galaxy Tab 4 (8.0) > Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8.0) Ask Verizon:
  • How to Factory Reset the Galaxy Tab 4 - YouTube www.youtube.com/watch?v=nZBZYa4nZ18
    • BY ASKTHEANDROIDGUY
    • 3 MIN
    • 110K VIEWS
    2014-05-19 · Video embedded · How to Factory Reset the Galaxy Tab 4 Check Out Our New Website: http://www.RickytheAndroidGuy.com Like us on Facebook: ...
  • SAMSUNG T330 Galaxy Tab 4 8.0" - How to Hard Reset my ... www.hardreset.info/devices/samsung/samsung-t330-galaxy-tab-4-80 Hard Reset SAMSUNG T330 Galaxy Tab 4 8.0" First method: In order to switch off the tablet hold down the Power key for a short while. After that, press and hold ...
  • Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset ... solverbase.com/w/Samsung_Galaxy_Tab_4_8.0:_Hard_Reset_Factory_Reset Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset. From ... How to make a Hard Reset (Factory Reset & Data Wipe) on Samsung Galaxy Tab 4 8.0"? Samsung ...
  • Samsung Galaxy Tab 4: Steps For Hard Reset - Technipages www.technipages.com/galaxy-tab-4-hard-reset How to perform a factory hard reset on the Samsung Galaxy Tab 4 tablet. Technipages Smart phone, gadget and computer tips. ... Samsung Galaxy Tab 4: Steps For Hard Reset.
  • https://www.android.com/tablets
    May 23, 2016 | Samsung Tablets & eReaders
    Galaxy DX99V parts
    how about galaxy.they still stock everything.
    Mar 03, 2013 | Galaxy Radios DX-99V 40-Channels Base CB...
    Ethernet conection dosen't work
    More than one computer or just one? Sounds like something wrong with the computer lan port.
    Jan 10, 2013 | Computers & Internet
    Not cool even set the temperature to maximum cold, here the circulation fan running but not the compressor runing (I guess).
    Sounds like the compressor has failed,But there may be a chance that the relay overload assembly may be faulty check same and replace and if compressor dosen,t start probably faulty compressor.Hope this helps Kind Regards.
    Jul 09, 2009 | Jenn-Air JCD2389G Side by Side...
    Whirlpool Side by Side not cooling, not making ice,
    your start system is out on the compresser you wil need to replace it you can get a factory oring. or uy a gernic kit like a Supco Pro-41 it will fit all ref. at half the price
    May 10, 2008 | Refrigerators
    Stopped working
    Unplug the ref for a couple of hours ( let the compressor cool off) plug it back in. If it still clicks, replace the relay, if the compressor still won't start then the compressor is bad. Last rights at this point would be appropriate.
    Mar 18, 2008 | Maytag 22.1 cu. ft. Bottom Freezer...
    Cannot copy video onto memory card
    i have a sandisk 2.0 gb conpact flash copies ok but can take 45min to copy 5 mins of suvalience
    Mar 20, 2007 | EverFocus EDSR100
    Refrigerators Logo
    70 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
