Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Blinking 11 in the temperature gauge and the red pilot light is blinking
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Ignition failure. Make sure you have gas, check the flue pipe on both exhaust and air side. Look into the window when you try to start up to see if the igniter arcs.
Tom
Posted on Oct 13, 2010
The pilot light on the water heater went out and the red light is blinking four times on the thermostat (Honeywell WV8860B1317). How do I get this to stop so that the pilot light can be relit?
The flashing light 4 times indicates high water temperature has activated the over heat sensor, and that the only remedy is to replace the gas control valve/thermostat.
Dec 08, 2014 | Water Water Heaters
Electrical ignitor on Kenmore Hot Water Heater Not Working
The water heater uses a thermocouple to generate a small voltage from the pilot light. This voltage is used to blink the led and allow the main gas jet to turn on. Either your thermocouple or the wiring from it has failed and needs to be replaced, or realigned if perhaps it moved out of position above the pilot light.
Mar 26, 2017 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
My heater keeps blinking and a code on the top says 11...also ..if i unplug the unit while i wait for it to get fixed does the pilot light go out?
There is no pilot light on this model. An 11 error code tells us that there is no gas supply to the heater. Could be a bad gas valve, dirty igniter, gas got shut off somehow, dirty burner, etc... All you can do is make sure the filter is clean, a technician will need to open it up. Sorry.
Apr 09, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Honda Pilot 2004 Car battery died because we left the lights on. Jumped battery. Works great but NOW the fuel gauge and hot/cold gauge is not registering. The fuel gauge needle just stays past Empty and...
Check fuse No. 9 (10A) in the driver's side kick panel fuse box. But if your other gauges are working (speedometer, tachometer, low oil light, etc.) then it is possible that when you jumped the battery you inadvertently reversed the cables and created a reverse voltage. This will impact some of the vehicle electronics. If you feel this might be the case, you should test the cooling system temperature sender to see if it failed. If it did, you should suspect that the fuel gauge drive circuit located in the instrument cluster is also failed.
Feb 09, 2011 | 2004 Honda Pilot
Sony trinton 27inch red light blinks 11 times
those LED flashhing codeds are useless. You most likely have a problem in the high voltage circuits. You should bring that one to a local shop as it's very nlikely you can fix it yourself, and the high voltage circuits are dangerous.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Mar 22, 2009 | Rinnai Digital Remote Water Heater Control...
No hot water
An error code of 11 equals no ignition. Check gas supply, sparker, flame rod, burner and ground.
Nov 27, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
139 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
