Question about D-Link AirPlus DI-524 Wireless Router
No internet Connection
HI, i have a DI -524, and i have been working these last months fine with no problems, since i had a shutdow at my house, it lost the internet conection, it is working the network but i can access to the internet, the cable modem is a surfboard motorola, and is its ok, i have to connect directly to the modem so i can acces to the internet, i reset the router and configure again, but i can not acces in the internet through the router.
Help me with issue, Thanks
  • 1 more comment
  • Anonymous Jun 01, 2008
    I have been using my router for the past year, but cannot get the wireless to work anymore.. I have tried resetting it but its still not working at all.
  • wmeddy Jun 04, 2008
    i play pogo games after a few mins. it will freeze then boot me out and say i am notcont. to server if i unplug it for 10 mins. then get back on line it is ok
  • Anonymous Oct 25, 2008
    same
    Genius:
  • 1,224 Answers
This is something simple
2 things you will have to do
the router when a problem like this happens again
unplug router for 1 minute this is packet build up and then plug back in i found this out by service provider that its a build up of packets it relieves packets
now the other thing since you went threw all the little areas of trying to reset modem go in remove your network connection
delete it and build a new network connection threw the network setup wizard then your done restart comp everything should be back to normal and you wont have to ever reset network settings again
just unplug the router let sit for minute and plug back in
Posted on Jun 01, 2008
The router is working fine and the signal is great throughout the house but the system is locked and I cannot remember the wep key. My buddy changed it last time we worked on it and what ever I wrote down...
In order to find the wireless security page of your D-Link AirPlus DI-524, please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page.
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link AirPlus DI-524 Wireless Router
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
DI-524 not working with Vista32 Dell M1330
make sure your wireless card is set to "obtain automatically an IP address"
Jan 25, 2009 | D-Link AirPlus DI-524 Wireless Router
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
Installing a DI-524 router
Hi askar,
I'm assuming if you've been given a username/password you've either got DSL (a PPPoE connection) or it's for your email address. If you don't have a disc for your new router, you can configure it through a wired connection to the router (using an ethernet cable). That's a bit of work but if you need to do it that way we can help. Otherwise run the CD that came with the router (again, you'll need a computer plugged into it) and the step-by-step should get you through it.
For starters, unplug the modem and then plug the cable running from the old router into the same port space in the new router (should say either WLAN or Uplink). Turn on the modem, wait 30 seconds, then power on the router. After that run the disc and you should be good.
If not, let me know!
Ben
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 One wireless connection makes others not ok
This is unusual, as it seems the router is allocating two pc's the same IP address. Go into your routers settings (internet browser and type the router address, eg 192.168.1.1)' and look at Client DHCP list and look at the IP addresses that each pc has been given and see if two are the same, they should be one digit difference, that being the last. Also go into the properties of both your pc's wireless cards and ensure that they are set to obtain an ip address automatically.
Jan 10, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
110 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
