Question about Russell Hobbs RHTCOB328D 1800 Watts Toaster Oven with Convection Cooking
I have a Russell Hobbs Russell Hobbs RHTCOB328D convection toaster oven. The top element has stopped working in either the bake or broil setting. Is this able to be fixed?
2 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Posted on Apr 02, 2009
The middle black knob on my toaster has been lost which then prohibits me from switching the setting from broil to bake etc. How do I got about getting a replacement knob for my toaster oven?
Try this web address for a list of websites that sell oven parts. Hopefully you will find one that carries it.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Mar 13, 2011 | Euro-Pro EuroPro 6Slice Toaster Oven with...
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Apr 01, 2009 | Russell Hobbs Toaster Ovens
Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Russell Hobbs RHTCOB328D 1800 Watts Toaster Oven with Convection Cooking Logo
44 people viewed this question
Top Russell Hobbs Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Russell Hobbs Toaster Oven Expert? Answer questions, earn points and help others
