Question about Motorola Mobility RAZR V3
Cannot call or receive
Everything works but can not make or receive calls. The white dot is red. I'm told this phone was exposed to water. What are my options. We have had the phone two month's.
    Sergeant:
  • 282 Answers
You can try with cleaning the whole PCB.
Posted on Jun 01, 2008
How can I tell if my LG Dare has water damage? I don't see one of the white or red round dots that people talk about.
In order to check for water damage you need to remove the back cover and battery and check for a square or a dot on the back of the phone, this is called the LDI (liquid damage indicator). If the LDI is white then its not water damage, if its red or pink then the phone does have water damage. If you don't see the LDI it might have been removed by someone or by the water itself, you need to take it to a Verizon store so the can check the internal LDI.
Hope this helps,
joe
Feb 25, 2010 | LG Cell Phone Accessories Bundle for...
G1 got wet-end button acts like it's stuck & back key doesnt work
call and get it replaced. DONT TELL them about the water. simply state it doesnt make calls and get them to send you a waranty replacement. It is free, but remember to tell them there is no damage to the phone, as long as the white dot is still white and the phone doesnt look physically damaged you are good to go
Aug 24, 2009 | HTC G1 Smartphone
I spilled sprite on my g1!!
I dropped my motorola sliver in the bathtub full of water and it quit working totally. I called ATT where I got the phone and they told me to look under the battery. I lifted out the battery and they asked me if there was a white dot under it. I told them no but there was a red one. They said "gone". Meaning that the dot was usually white but if it turns red, the circuits are water/liquid damaged and to throw it away and get another phone. Look under your battery.
Apr 17, 2009 | HTC G1 Smartphone
When I receive calls I do not hear the person but they can hear m
when i had a phone like that it had water damage. take out the battery and look for a red dot on the back.. it is supposed to be white but if it is red or pink-ish then its water damaga.hope i helped.
Apr 07, 2009 | Samsung BlackJack II Smartphone
My motorola razr v3 screen keeps going all white!?!
first, make sure your Razr has no physical or water damage. If it's a T-Mobile phone, there will be a red sticker on the phone behind the battery. That indicates the phone as been exposed to water damage. Could mean the phone is shorting out on you. Now, I would suggest if the is NOT water damaged, to powercycle (turn off and on the phone) daily. Just off for about 30 seconds. Not long at all. If the white screen continues, do a master reset. Settings, -intial set up-master reset-code is 1234 or if you put in a different security code.
This will work!
Jan 29, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Phone wont charge
Did you drop your phone in water? or do you live in a humid area?
Your phone was exposed to moisture. That red dot is a moisture sensitive piece of tape that changes colors when it gets wet.
If your phone still works, but the battery won't charge when connected to a home charger, you might try charging it in your car. Its a different type of current and may work with a somewhat damaged battery.
If that fails to fix the problem you may need to get a new battery.
Hope this helps
Jan 15, 2008 | Motorola Mobility RAZR V3
Motor Razy 3xx cellphone
yup...
its common prob for razr. if you can open your fon, check its flex coonector inside mayb it get loose thats why you dont have any display, if everything is fine... probably you have a defective flex connector or defective LCD...
Oct 26, 2007 | Motorola Mobility RAZR V3
Motorola Razor Water damage??
have talked with others who tried blow drying & then putting in freezer for few hours with phone & battery separate & yes the red normal after getting H2O damage shows the company out of warranty if you exchange phone through the warranty will be billed I think its like 110 or165 for At&t but if you call talk with them & tell them that phone stopped working screen blanked out & NO the red dot not there that it is white & ship your phone back when they receive it you will then be billed for it BUT when you call back in repeat OVER & OVER that when you sent it in that it was white & not your fault that warranty screwed up most of the time if you complain long enough you will get the charge removed :-) (work for cell company)
Aug 30, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Water Damage
this is a stick and whens it get wet it change color into red.dont be worry is nothing
Aug 20, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
