Question about Car Audio & Video
How do you replace front door speakers on 2004 chrysler pacifica
turo1000
  • 18 Answers
SOURCE: program instruction garage door opener in 2005 chrysler pacifica
if your garage motor have rolling codes you need to put your car inside garage near the motor leave ignition on go to the motor locate learn button press it then quickly go to the car and press and hold one of the buttons for approximately 30 sec or until it start blinking rapidly, if you have a regular motor take one hand held opener go inside car ignition on same time press open button on handheld remote and on the car button 30 sec and it should be programmed.
Posted on May 18, 2009
  • 323 Answers
SOURCE: 2004 chrysler pacifica
It is for an oil change mainly and any other service your maintenance manual suggests at the mileage interval. It needs to be reset after each oil change to be accurate.
Posted on Jun 05, 2009
  • 61 Answers
SOURCE: 1999 Chrysler 300M door post speaker
www.Crutchfield.com
They have a web page to outfit your particular model
click on main store, then click on outfit your car.
hope this helps
Posted on Sep 16, 2009
SOURCE: 2004 chrysler pacifica, front blower not working,
replace restor open glove box uplug 4 wire plug and two wire plug put 12 volts two wire plug to mke sure fan works if it does replace restor
Posted on Dec 27, 2009
  • 1024 Answers
SOURCE: serpentine belt routing for 2004 chrysler pacifica
here it is
Posted on Apr 13, 2010
Where is my TCM located in my 2004 Chrysler Pacifica all wheel drive
its located near the battery , generally inside front bumper driver side
May 25, 2017 | 2004 Chrysler Pacifica
My front blower stopped working in my 2004 Chrysler Pacifica. Where is the blower motor located so I can replace it?
BLOWER MOTOR IS LOCATED PASSENGER SIDE UNDER DASH. MIGHT HAVE A THIN PLASTIC TRIM COVER OVER IT
Jun 24, 2015 | 2004 Chrysler Pacifica
How to replace an actuator for a 2004 Chrysler Pacifica
It would be helpful to know which actuator you are needing help with. Blend door, Mode door, Recirculation door (I think that's all of them).
Jun 12, 2014 | 2004 Chrysler Pacifica
2004 Chrysler Pacifica Blower won't work
Usally when a blower motor resistor goes bad the fan still runs on high. The resistor lowers the voltage going to the fan to make it run slower. The high setting usually goes straight thru. Resistors are usually easy to get to, under good on the firewall or under dash passenger side. Cost about $24 at parts store. Replace with new if that doesn't work return it.
Aug 29, 2012 | 2004 Chrysler Pacifica
Liftgate 2004 chrysler pacifica ajar light comes on and off how do I reset this problem
close the door with a dollar bill in between move it around door and see if it is loose if it is slide the lower bracket in to make door tighter light should go out
Sep 26, 2011 | 2004 Chrysler Pacifica
Rt tail light and front marker lights not working, bulbs fine, no fuses. Whats the problem?? 2004 chrysler pacifica
My 2004 chrysler pacifica , lift gate is not open , not closing ,and i tray remote to open dosen,t work ,using by the hand nothing ,i check everything ,and i dont know wher the problem is ?????????
BEKIM
Apr 02, 2011 | 2004 Chrysler Pacifica
2004 chrysler paicifa. Left Front Door Ajar Error
The door latch in the door is the switch. Unplug insde the door or replace latch
Mar 04, 2010 | 2004 Chrysler Pacifica
2004 chrysler pacifica, front blower not working, rear blower strong but cold.replaced relay no change
Dec 24, 2009 | 2004 Chrysler Pacifica
Car Audio & Video Logo
146 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
