Question about Memorex MVDP1072 Portable DVD Player
I can hardly see the image on the screen. Screen background is dark.
  • 10,594 Answers
Back light system in this dvd player is not working properly that is why you see very dark image.
LCD Screen needs light source at back to present its image on front.
Visual check of back light inverter circuit is needed by repairman as it is not user level repair because dvd player will take apart to examine it. Local tv repair shop will help you.
Hope these info will help you.
Thanks.
Posted on Oct 12, 2010
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
Dark Screen and Blue Lines Arc Across Background
Hello!!
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Dec 28, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Screen keeps t going blank but still have power
It may be the internal backlight that is failing. When the display has failed but still has power, take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Mar 24, 2011 | Xerox XG-91D 19" LCD Monitor
My proview 19 in turn on but then it goes black is it a capasitor and how to fix it or is ther a reset on it
It may be the internal backlight that is failing. You can take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Mar 22, 2011 | Proview PL926WBi 19" LCD Monitor
I am running Windows 7 (32 bit) and am seeing ghosting behind the fonts as I scroll them with smooth-scrolling in Firefox and Thunderbird. It is especially visible when viewing on a dark background. I have...
Hello!
First things first!
Usually these problems, its related to monitor or monitor drivers, check the cable conection to the back of monitor, if is HDMI or analog, that is well conected!
other may be bad power cap, or damage, or high freq. static in lines.
hope these hints, helps
Carl
Jan 06, 2011 | HP GeForce 8400GS Graphics Card - nVIDIA...
Background ghost like images
CHECK IT IN THE DIFFERENT ASPECT MODES. IF THE IMAGE STAYS IN THE SAME PLACE REGARDLESS OF ASPECT. THEN YOU HAVE A LCD PANEL PROBLEM. PANEL WILL HAVE TO BE REPLACED.
Feb 27, 2009 | Televison & Video
Dell inspiron 5150 dark screen, faint image in background
If it showed a pinkish tint on the screen before it went out it could be the backlite. If you can see a faint screen when you turn the room lights out it chuld be the inverter. Inverters are cheap ... a used one for around $8 on ebay. Try that first. Make sure that you buy the EXACT model that is presently in your laptop.
Jan 14, 2009 | Dell Inspiron 5150 Notebook
Dark screen with dull image in background
You may need to check your desktop image for your monitor and change it to something lighter
The external monitor usually uses your computer's default and not ncessarily the one from your laptop monitor
Without taking it apart myself, it could be some wiring from the laptop to the screen
Dec 13, 2008 | Computers & Internet
IN72 psychedelic traces
have the same problem took mine apart for cleaning and inspected the bulb looks like bubbles in the bulb that will hold disorted images on the screen so im going to replace bulb
Feb 04, 2008 | InFocus IN72 Multimedia Projector
Memorex MVDP1072 Portable DVD Player Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
