Question about Akai Televison & Video
I have a 32 inch AKAI LCT320TD and it is hooked up to a direct tv box via coax coming in from the satellite and then it is connected via composite cables to the TV. When I turn on the TV the power light is Green and then goes Orange and eventually RED? What is the orange status mean? and How do I get a least snow to show up on the screen. It's black the whole time that the power light changes?
lukster
  • 217 Answers
SOURCE: black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
Posted on Feb 17, 2007
johnychel
  • 796 Answers
SOURCE: cant turn tv on
may be your DM board is gone......
Posted on Mar 08, 2008
Twizted
  • 30 Answers
SOURCE: Akai LCT2715 Led blinking orange and set won't turn on
There are about 16 to 17 capacitors that are a common fail point on this TV. I can repair your power supply board with new high quality capacitors and recondition the board to work like new for $100 + S/H, you simply have to send me the power supply module and turn around is approx 2 days from the time I receive the package to the time its out the door. Approx 8 business days according to the delivery carrier you use.
Posted on Jun 25, 2008
experttv
  • 203 Answers
SOURCE: Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Posted on Sep 14, 2008
  • 41 Answers
SOURCE: HOOKED ELEMENTS FLX3210 TO LAPTOP TV DIED ONLY RED LIGHT WILL COME ON
Sounds like you need a new main board the light in the front comes on when you push the power button right?
Posted on Oct 07, 2008
Can you hook up a digital converter to a akai model num lct3201td 32 inch tv
The converter box connects to the antenna input of your TV or, for better picture quality, L audio, R audio, and video outputs from the box can be connected to corresponding inputs on the rear of your TV.
Nov 02, 2016 | Akai LCT3201TD 32 in. LCD Television
How to connect the cable to my Akai tv set without a cable input? I don't have a cable box.
If you get a cable box that has audio/video outputs on the rear connect them to a identical input on the rear of the set----direct connection and bypasses the coax fitting most sets have.
Go to the input you hooked to and leave set there--change channels via the box with its remote or manual buttons.
May 27, 2012 | Televison & Video
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
Aug 08, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Jul 07, 2009 | Televison & Video
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Jan 14, 2009 | Onkyo TX-SR606 Receiver
I broke off coax cable on back of 32 inch tv. I can watch dvds with AV cables but not cable TV. How do I connect cable from wall to tv if coax is broken off
This depends on how many available inputs you have on the back of the set. If you have more available you can just hook up the cable box composit (yellow, red, and white cables) if not you will need to replace the rf connector or tuner in the set. let me know if you need more help.
Tim
Sep 11, 2008 | Televison & Video
Hooking up a dvd/vcr player
The easiest way to connect the unit is via coax. You can come out of your satellite receiver via the "Out to TV" on the back of the receiver to the "In from Ant" on your DVD/VCR combo. You can then connect another coax from the "Out to TV" on the DVD/VCR combo to the "Ant/Cable" input on the back of you TV. Make sure the satellite receiver and the vcr are both modulated to the same channel, normally channel 3.
Dec 31, 2007 | Emerson EWF2004 20" TV
36 inch toshiba Tube tv manifactured in 1997
Program TV =
1) set-up.....Select CATV also called STD Cable
2) Auto-program channels.........
.......Owners manual ? Let me know.................T.
Dec 11, 2007 | Toshiba 32AF43 32" TV
Olevia LCD 32 inch
You can hook up direct but you will not get hi def channels, only the standard or digital depending on your hook up.
Oct 12, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
