Question about Day-Timer Intermatic Ei600c Digital 7 Day Timer 20 Amp 24277v
Is this okay to use with CFLs. Cannot find any reference to CFLs in brochure or manual. Intermatic EI600 wall timer
A timer turns the circuit on-and-off just like a switch
Anything a switch can turn on-off, a timer can turn on-off
Things get complicated when using a dimmer, but not a timer
Posted on Oct 12, 2010
  • Anonymous Feb 27, 2011
    Manual shows: Ballast (fluorescent) 16 Amp @ 120-277 VAC. So I guess it will work for CFLs. Open following link for EI600 manual:http://www.intermatic.com/~/media/files/... - english.ashx
I have an Intermatic E1600 Digital Wall Timer and I cannot remember how to reset it to an earlier time...and I have misplaced the instruction manual. Any help you can give me is appreciated! Steve
You probably have Intermatic Ei600 which is 5-year warranty timer that uses CR2 battery, and has same programming steps as lighter-weight Intermatic ST01C timer.
Open following links to identify timer, read ez set instructions, and download manual.
http://waterheatertimer.org/pdf/Intermatic-ei600c-manual.pdf
http://waterheatertimer.org/ST01C-program.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
The timing programs for Ei600 and ST01C timers remain in memory indefinitely even if battery goes dead. If you re-program current time and date, the original programs are still there.
If timer stopped functioning, then replace battery. Usually with battery replacement, the timer must be re-set which clears all programming.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Intermatic EI600LAC Electronic Timer
Re Intermatic ST01C White Self Adjusting Wall Switch Timer Pgm indicates "SNST". I can't change it?
Last ditch troubleshoot for ST01C is to change CR2 battery and then reset timer.
Battery is inside compartment located below programming buttons.
How to reset: Hold down on-off button. Push reset momentarily. Keep holding down on-off until display shows INIT. Release on-off button and 12:00 is flashing. Reprogram timer.
If functionality is not restored, then timer is bad.
ST01C has 1 year limited warranty.
Heavier duty Ei600 is same timer, but has 5-year limited warranty.
Open following links for ST01C and Ei600 wiring illustrations, battery illustration, and programming, manuals and resources:
Aug 01, 2011 | Intermatic & Self-Adjusting Wall Switch...
The unit acts dead. new battery is no help
You changed battery. Make sure + and - are correct. Using alcohol, clean terminals. Clean contact points that stab into timer. Let dry. Push in battery carriage.
Aug 01, 2011 | Intermatic Inc. ST01C Digital In-Wall...
My wall installed intermatic timer will not shut offf. Either by the program or the manual switch. Help appreciated
Timer model is not known.
Last ditch troubleshoot for ST01C, EJ500, and Ei600 programmable timers is to change battery and then reset timer.
Make note which way battery/batteries come out for easy replacement.
How to reset these timers: Hold down on-off button. Push reset momentarily. Keep holding down on-off until display shows INIT. Release on-off button and 12:00 is flashing. Reprogram timer.
ST01C and EJ500 have 1 year limited warranty.
Heavier duty Ei600 is same as ST01C, but has 5-year limited warranty.
Open following link to identify product, and then add a comment for more help if needed.
I can't download the instruction manual from Intermatic's website. I have a EJ500C timer and want to know why they caution against using it with CFL's and how to program it to shut off...
EJ500 7-day or astronomic timer is incandescent light bulb timer.
Different timers have different Load ratings.
Intermatic ST01C timer can control CFLs.
Aube timers have same wiring capability as Intermatic, and offer CLF control, but you have to choose either astronomic timer, or 7-day timer.
Open following links for manual and timer information.
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
http://waterheatertimer.org/Aube-timers.html
Jul 16, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Looking where to find an instruction manual to reprogram my intermatic astrological wall switch the e1600
You posted under E1600.
Maybe you have Ei600
Ei600 5-year warranty is heavy-duty version of Intermatic ST01C 1-year warranty
One thing to note about this timer, the programs remain in memory indefinitely until timer is reset.
You might only need to reprogram current time.
Open following link to identify timer, and download Ei600 manual, and read ez wiring and programming instructions:
Upvote the help.
May 30, 2011 | Intermatic EJ500C - Indoor Digital Wall...
I want to reprogram my timer to a new on time,and off time. do i have to clear the existing program,and start from scratch? if yes, do i use 6a an on/off program at specific times. next question: ...
To reprogram times, it might be easier to clear all programs. Read the manual. Sometimes you have to read it several times. Or scan it into computer so you can see print larger. Or go to manufacturer website and download manual. Some manuals are impossible to find, some have unclear instructions.
For programming help. Post brand and model number of timer so product is identified. Some products have nearly identical numbers but are very different. It's a zoo of products. So be specific.
Timers generally repeat 1 week or 1 day. Do you have a in-wall timer? Or box-type timer
Intermatic in-wall EJ500, ST01C, EI600 offer Daylight Savings & Dusk to Dawn operations. EI600 has 5 year warranty. Other two have 1 year warranty.
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%207-day%20astro%20time%20switches.aspx
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Click product number to see manual. Download manual to your computer> go to File at top of browser, click 'save' -or- click 'print'
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you have a boxtype timer, Intermatic makes timer with photoelectric sensor
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
Aug 14, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Day-Timer Intermatic Ei600c Digital 7 Day Timer 20 Amp 24277v Logo
120 people viewed this question
Top Day-Timer Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Day-Timer Hardware and Accessory Expert? Answer questions, earn points and help others
