Question about Hoover U6311-930 Power Drive Bagged Upright Vacuum
HO-48414013 need this part for an hoover U6311-930 brush any ideas on where to get one
The brushes on my hoover f7411-900 carpet cleaner will not turn. any ideas? thanks, Hank
The most common reason for this is that the air driven turbine that turns the brush has seized up. To test it, remove the brush and insert a flat screwdriver into the square hole that the pin on the brush normally fits into. If you can't turn the fitting with the hole in it, the turbine assembly will need to be replaced. ( part # 91001019 ) - msrp $19.99. Be sure the square pin has not broken off from the brush assembly, as this is another possibility.
Apr 29, 2011 | Hoover Vacuums
I have a Hoover SteamVac Carpet Cleaner with Clean Surge. I lent it to my mother who used it without the brush attached underneath. Now it doesn?t **** up water and the brushes don?t turn. Any idea what...
If you go to this URL:
http://www.vacpartswarehouse.com/Hoover-F7452-s/811.htm
you will an exploded view of your Hoover. By going down the pictures you will be able to see the internal parts of the unit and how the brushes are driven. You can check the parts in your machine to see if there is anything obvious about the drive system.
Please let me know how you make out, I am more than willing to discuss with you what you find and any possible solutions.
Paul
Sep 19, 2010 | Hoover SteamVac F5914-900 SpinScrub...
On our Hoover U6445-900 (Mach 6.9) we replaced the small belt that goes to beater brushes in front of unit. Upon starting, the Hoover quickly got hot and smoky. We shut it off and looked things over...
are you sure you purchased the right size belt..the friction you speak of is usually caused by a belt not being the right tightness or a jammed beater brush
Dec 19, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
My Hoover doesn't roll
You need to replace the belt. Part number 40201160
Oct 07, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Wheel in Hoover SpinSrub turbine broke
Sorry, you will not find that one part available for sale. You will need the assembly from the manufacturer, or may check online sales/auctions.
Nov 20, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F425-900 Steam Vac V2
Check the brush block to make sure that the shaft going into the turbine is ok, if it is, then the turbine will have to be replaced.
Dec 29, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
How to open the hoover DM4526 to change the belt
there are normaly5screws 3in the front 2in the back remove these and the bottom should come off pull the brudh off repace belt on to brush put brush back in to seating pull brush on to drive and re,asemble
Dec 06, 2007 | Vacuums
Hoover U6311-930 Power Drive Bagged Upright Vacuum Logo
244 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
