Question about Sony Handycam HDR-UX5 DVD Camcorder
Says disc is dirty or scratched ...it's not
The screen gives an error code and message that says disc is dirty or scratched. It does this with all my discs and on disc that was in recorder that worked fine the night before
  • 10,594 Answers
Eject the DVD disc and push Optical Lens inward-outward for 2-3 times carefully. Please dont touch lens surface. Lens should reach completely at both ends.
Hope problem will be solved.
Posted on Jun 01, 2008
Won't recognize the disc as a game... how do we fix this? Its a brand new Wii game.
Check the bottom of the Game Disc (the side without any labels or writing) for any dirt or damage (such as cracks, scratches, etc.).
If the games look significantly damaged, such as with scratches or cracks, it will need to be replaced.
If the game looks dirty (fingerprints, smudges), try cleaning the Game Discs. If the problem persists, the Game Discs will need to be replaced. or Click here to download repair guide
Dec 22, 2010 | Nintendo Wii Console
Tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Feb 18, 2010 | Video Game Consoles & Games
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
Navigation not working get disk reading error message upon starting car and every few minutes afterward
Check for a scratched or dirty Navi DVD disc. Clean or have the scratches polish out at your local game store. Video game stores usually have a disc repair machine that polishes out scratches.
Note: In some cases the Navi unit can cause rotational scratches on the DVD. If this is the case than the Navi unit will have to be replaced.
Oct 05, 2010 | 2003 Honda Accord
Disc won't play
As the Wii uses discs that can be scratched, dirty, or otherwise damaged -- it's important to first check the disc.
Look for fingerprints or other smudge marks. If you have dirty marks on the disc, you can wash it off with regular dish soap and water. Not too much soap though. Make sure you dry it off with something very soft [like a microfiber cloth] before you put it back into your Wii.
Second -- scratches will stop a disc from playing... or the disc will play until it gets to the scrached section then give you an error. Check and make sure there are not too many -- or deep scraches.
If a scratched game won't play through but other games play just fine -- chances are the disc is bad. However, if nothing is playing through on your Wii, not even a new game, there is a problem with the Wii's DVD drive. There is a laser in the drive that reads discs -- and many other moving parts in there. The following website sells the Wii DVD drives. It's not too difficult to replace yourself:
http://store.richspsxparts.com/wiiredvddr.html
Sep 06, 2010 | Nintendo Rock Band for Wii
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
Feb 18, 2010 | Microsoft Xbox 360 Console
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
PS3 Error message...
This is the error code for disk errors: "An error occurred during the start operation. (8001002B)". If the disc is clean, maybe the laser is dirty. Use a lens cleaning CD to give the laser a clean (cheap to buy). You can also try deleting the temporary game data (using Game Data Utility) and reinstall the game.
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Feb 08, 2009 | Denon DCM-5001 100-Disc CD Changer
Error #701
The error message means cannot read from disk. Your third disk must be dirty, faulty or scratched.
If it is dirty wash it in cold water, rinse well with dry cloth taking care not to leave cloth fibre on disk, then try again.
If it is scratched or faulty I suggest asking a replacement from Panasonic.
regards
Mar 14, 2008 | HP Pavilion dv6000z Notebook
Sony Handycam HDR-UX5 DVD Camcorder Logo
298 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
