Question about Garden
7/8 hp router sounds like it needs lubrication, but where?
  • 43,501 Answers
Turn the router upside qown ans first spray around the shaft with WD-40...
Let that soak preferably overnight...
Then place a few drops of light motor oil around the shaft right where the shaft comes out of the motor housing... with the router still in the upside down position. Then let that set for at least 12 hours to give it time to run down and into the shaft bearing and lubricate it.
This should get it running better and quieter...
heatman101
Posted on Oct 12, 2010
Why will my pavilion dv9000 only connect to public access networks, and not wirelessly to any home networks?
sounds like
a. wpa or wps needs to be reconfigured at router
b. firmware for router needs attention
c. router is truly unhappy about wireless settings
check router website for management access and adjustment procedures
not an hp issue
May 30, 2012 | HP Computers & Internet
My hp 2840 all in one laser jet printer squeaks when it is printing. How do I lubricate my 2840 HP laser jet printer?
Corosol technology is older,slower sounds also too high, it is not suggestible to lubricate the moving parts because of cartrides will move while printing result lot of toner particles raises in printer chamber,if this particles deposited on lubricated area will abstract the moving spares. If you can do the periodical maintenance, use silicon grease for moving parts..
Sep 28, 2011 | HP LaserJet 2840 All-In-One Printer
Transmission lubricant
The grade of the transmission lubricant for your vehicle will depend upon the climates temperature where your vehicle is operating. You need to ask your motor mechanic or refer to your vehicle's manual for the recommend lubricant.
Jan 07, 2011 | Computers & Internet
My HP J6480 ADF is making a grinding noise when I try and fax or copy documents fed thru the ADF. I have tried cleaning the rollers but that hasn't worked. Any other suggestions?
You need to locate, from where sound is coming from.
Then use wd40 or silicone grease oil, and lubricate.
its probably dirt on axis bushings.
Jul 05, 2010 | HP Office Equipment & Supplies
Plunge router is stuck in the router base. Porter Cabe 891 router is stuck in the plunge base. Released the buckle and won't come out. What to do? Thanks, Joe
If you are talking about the nut tap on it with a hammer, if you are talking about the tubes you can try cleaning them with air and then using some lubricating fluid to free up the piston/springs. Let me know if you need more help
Mar 15, 2010 | Porter Cable-Cable 891 2 1/4 Peak HP...
HP 170 color copier problem
Did you experience paper jam before.. Could ba a mechanical error on the gear on the printer that causing now the cartridge carrier to jam...
It is better to call HP if its under warranty, or you can send it for repair..
`micro
Jun 07, 2008 | HP 180 Color Copier
Carrage making sound in hp all in one,there is also a message paperjam
If it only happens when it is moving back and forth then the rail needs to be lubricated.
open and put some wd40 on acloth and wipe the silver bar to lube.
Oct 19, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Lubrication?
It does sound as though it could be a lube issue. Use a light white grease to lube the bar the head runs on. Do not use things like WD40 or 3-in-1 as they can be damaging. Also check that any FCC cable to the moving parts are not just catching on an inner surface somewhere. This can sound like finger nails down a chalk board.
Jun 14, 2007 | HP 920 Plain Paper Fax
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
