Question about T-Mobile Sidekick II
Sidekikc II power is on display on screen how you turn device of and on
First tell my
Posted on Oct 22, 2010
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Won't record
I suggest that you to select Reset to Factory Defaults in the System menu to soft reset reset the unit or by pressing Delete and the power button and holding them down to hard reset. Good luck!
Dec 14, 2007 | M-Audio MicroTrack 24/96
Tip
Galaxy S4 I9500 LCD LCD Assembly
Appropriate for: GT-I9500, GT-I9505, SGH-I337, SCH-I545, SPH-L720, SCH-R970, SGH-M919
Regarding Samsung Galaxy S4 I9500 LCD Display screen and also Digitizer Assemblage Substitute : Sapphire
This kind of merchandise contains:
1. LCD Display screen;
a couple of. Digitizer Touchscreen display
When you examine Samsung Galaxy S4 Digitizer and also LCD display screen assemblage and also Samsung Galaxy S3 Digitizer and also LCD screen side simply by part, the most significant variation will be the outside ends with the S4 are usually seemingly more compact as compared to in which about S3. The particular size involving the side as well as the principal exhibit location is 1. 5 mm, not even half of the with the S3 helping to make a lot more area to match a more substantial display screen. There is certainly one more gap around the higher still left part with the Samsung Galaxy S4 which usually doesn't show up about any mobile phones just before it could be some type of sensor or perhaps a great DIRECTED notification
Once we turn over the 2 LCD display screen assemblies, we all can easily see the contract cable tv connectors around the a couple of monitors come in diverse opportunities, regarding S4, the particular contract cable tv will be at the top, but also for S3, the particular contract cable tv will be in the bottom.
Once we go through the display screen assemblage using this perspective, we could note that the goblet contact lens and also digitizer powering that are usually leaner in comparison to the particular S3.
Today let's have a look at the particular Samsung Galaxy Take note II Digitizer and also LCD screen compared with all the Samsung Galaxy S4 Digitizer and also LCD display screen. The particular Take note II can be a huge cell phone, the particular side across the display screen with the Take note II will be a couple of. 8mm, practically twice in which with the S4 as well as the Take note II provides a couple of contract cabling around the again although S4 simply provides a single. The particular fullness regarding Take note II is significantly plumper compared to the S4, specifically the particular goblet contact lens.
For Samsung Galaxy S4 GT I9500 I9505 I545 L720 R970 I337 M919 I9502 LCD...
on Feb 15, 2017 | Samsung Cell Phones
Unlock Code for Sidekick II Juicy Couture
How to Enter Unlock Codes on T-Mobile
  1. Press the Menu key.
  2. Scroll to and select Manage Connections.
  3. Select Turn All Connections Off.
  4. Press the red end key or the Escape key to go back to the Home screen
  5. Scroll to and select the Options icon.
  6. Scroll to and select Advanced Options.
  7. Scroll to and select SIM Card.
  8. Type MEPD Note: When typing in MEPD the letters will not appear on the screen. This step opens up the personalization on the device.
  9. Hold down the Alt key and type in MEP2. Note: When typing in MEP2 the letters/number will not appear on the screen. This Step opens up the Enter Network MEP code box.
  10. Enter the unlock code.
  11. Press the trackball (code accepted should display).
  12. Press and hold the red End key to turn the handheld off and then back on.
  13. Once the device has powered on, follow steps 1 & 2 and select Restore Connections.
Dec 08, 2007 | T-Mobile Sidekick II
I have a canon t3i. The menu doesn't turn on when you turn on the camera.
The menu doesn't display when you switch on. You should get the settings screen appear. Once powered up just hit the MENU button
Mar 02, 2015 | Canon EOS Rebel T3i 600D SLR Digital...
When i turn my tablet it will not turn from portrait to landscape
Devices can be different, but check your Settings. Find Display. Make sure "Auto rotate screen" is checked. Or sometimes it may be as simple as powering the device off then back on.
Feb 12, 2015 | Eaton Le Pan Ii Tablet
Screen was blank but power light lit. Rebooted power light lit (light blue but no working screen?
Shut down system by using poer button on tower then unplug tower. Turn power back on and boot in "safe mode with networking". When screen comes up, click on "start", then "control panel". Find and click on "device manager", open and click on continue. Click on box(on right) of "display adaptors". Do you see a warning, ?, !, or yellow triangle? If so click on that and follow proceedure. Right click on your device and in the list you should see "disable". If you see "enable" click on that and exit. Right click on your device again and click on properties. You should see "this device is working properly". If you are using on board graphics, not a graphics card, click on "drivers" tab. Then click on "automatically search for updates...". When finished, restart your system. If you have a graphics card you should update with manufacturer. Let me know make and model of card if you have one. If you are getting beep codes it could be your ram.
Apr 05, 2011 | Dell Inspiron One 2305 Desktop Computer...
I need unlock a sidekikc lx 2009 inmediatly i cant wait for a 15 days.how can i do?
hey i have att and trying to unlock my tmobile side kick i have the password for it but it keeps saying authenticating simcard then it turns off everytime
Oct 13, 2009 | T-Mobile Sidekick
I have a JNC digital concept power voice II
The part which shows the files to be downloaded from the JVC recorder does not open when the software starts up. It only opens when the recorder is detected attached to the USB port. I suggest 1. Start the software. 2. connect the JVC recorder to the PC with the USB cable. 3. Turn the JVC recoder ON. The recoder display says "PC link" and the files to download show up in Power Voice II on the PC. Michael C
Sep 30, 2009 | Audio Players & Recorders
Blackjack II will not start
This has happened to my Blackjack II and I've found if I plug it into the charger then plug the charger into the wall, the phone comes right on. It's a pain, however, if I'm not at home when it decides to do this since no amount of button pushing will turn it back on, it acts like the battery is dead (when I know it isn't!)
BTW, I've have to have my SIM card switched out twice and the battery replaced 4 times since I bought this phone brand new in February......
Aug 30, 2008 | Samsung BlackJack II Smartphone
T-Mobile Sidekick II Logo
13 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
