Question about Whirlpool Dryers
My dryer isn't heating up I replaced the thermal cutoff it worked for about 20 minutes and now it won't heat up again
  • Whirlpool Master
  • 43,501 Answers
Hi, Because the thermostat is also bad ans that is causing the thermal fuse to blow...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 15, 2010
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Dryer not heating
Its a good possibility that you have lost the nuteral connection at the power block or the receptical .
Jan 04, 2013 | Whirlpool LEN2000PW Dryer
I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
Mar 11, 2012 | Whirlpool Dryers
The dryer blew the thermal over load on the heater coil I replaced the over load and therostat and it blew the over load again. What should the ohms be on a good heater coil kenmore dryer model...
Hello, The ohms rating on the heat element should be appx.10-20 ohms. The reason a thermal cutoff would blow and the replacement also blow was a poor air flow issue, so to much heat was being retained in the heater housing. What ya would need to check is for lint build up in the lint filter housing and also a blocked or restricted vent tube.
GENE
Oct 09, 2011 | Dryers
LER7646 won't heat. I checked the resistance of the heating element (12ohms). The high limit thermostat reads 0 ohms and the thermal cutout read open on the ohm-meter. I replaced the thermal cutout and...
A typical reason the thermal cutoff would go out so quickly is because of a poor airflow so the heat is being built up in the dryer instead of being vented out.
What to check is for a blocked/restricted vent,lint built up in the blower housing that is restricting the airflow& or a broken blower wheel that isn't moving the air from the dryer.
GENE
Sep 05, 2011 | Whirlpool LER5636P Electric Dryer
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Nov 13, 2008 | Zanussi TC7114W Electric Dryer
Dryers Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
