Question about Coby TFTV1212 12 in. LCD TV
Coby TFTV1212 has frozen up. On power-up only one channel comes up with audio/video. Unplugging for several hours does not cure the problem. Unresponsive to both the remote and front panel buttons. Will not even power down from frnt panel.
3 Suggested Answers
  • 95 Answers
SOURCE: Lost TV remote for Coby Flat Panel TV, 17inch
Universal remotes are not compatible with any Coby TV. You can get a remote directly from Coby:
Send:
$6 Money Order - 'Made out to Coby Electronics'
note with your name, address, phone#, model# and what part you need
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
Posted on Aug 23, 2008
  • 8457 Answers
SOURCE: I have a Coby TFTV
The tv still new only 1 week old?Yes,return it where u bought it and get a new tv replacement.No?This tv have a 2 long boards that call the LCD inverter boards each sides left and right sides of the tv.Could be etheir one of these two of this long LCD inverter boards it is dead.Must have electronic equipments to test to know exactly with one it is dead.These 2 long LCD inverter boards only job are to probvided a backlight to the tv LCD screen panel to get a pictures.Both of these long LCD inverter boards are not that exspensive and very easily to take the apart and replaced.Tries websites like Shopjimmy.com,Ebay.com to buy both long refurbishes LCD inverter boards for the replacement.
Posted on Aug 11, 2011
Red light constantly on, can not get player to do ANYTHING @ ALL, only RED LIGHT ON
If you wish to get some details about audio equipment and its repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 21, 2016 | Coby CXCD380BLK Micro CD Player Stereo...
How do I copy mp4 files to coby mp625
I use the USB cable to connect my laptop to the tablet. Then find the correct music folder and drag them over.
Feb 14, 2015 | COBY-PERSONAL & PORTABLE Coby Mp620 4 Gb...
Trying to get my ps3, Emerson hd tv and coby DVD938 home theater all to work together
The DVD938 only has analog audio input (2.1 channel), thats why you have only a white (left channel) and red (right channel) audio connection from your ps3 to the home theatre. There is an option called PROLOGIC in the setup menu that will simulate 5.1 with the 2.1, it basically takes the 2.1 channels and splits it into all the speakers.
Mar 03, 2013 | Coby DVD938 Theater System
I can get signal
where did you buy the tv, might not the same broadcast signal in your location. by the way have you been tried to have manual fine tune of any local channel or auto search so you can get available channel in the area.
Nov 17, 2012 | Coby TFTV1212 12 in. LCD TV
What outlets do I hook up to on the reciever and the tv for it to play on regular tv stations
Cable Box optical Digital Audio to Coby Digital Audio In. (This brings TV-related multi-channel and normal audio into the Coby so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the Coby on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
Mar 01, 2010 | Coby DVD938 Theater System
Hooking up Coby Csp-94 Speaker to HDTV "no directions"
The green, black and beige cable is non-standard and proprietary meaning that Coby has defined their purpose which hopefully is described in your user guide. It would be worth a few dollars to buy the properly color-coded cables to uncomplicate your setup. Buy cables (or cable sets) that have the same color coding as your TV jacks along with the cable suggested below.
There are several ways to connect to an HDTV system and these are normally standard as previously described.
The red and white are for right and left channels and it isn't uncommon to see a three cnductor cable with one not connected since one of the methods of connection is to supply audio via two cables, video (composite) via a 3rd which is plugged into a corresponding jack, normally colored yellow. Audio cables aren't really required to carry the mix of much higher frequencies of composite video.
If you have the following connectors, try this:
- S-Video (this does not contain any audio information and requires an S-Video cable) - Right (red) and left (white) audio paths.    The S-Video connection provides a better signal that gives you a noticeably sharper picture. This setup is selected from the TV's input source menu.
Sep 07, 2008 | Coby CSP-94 Speaker
Remote code for Coby TV/DVD
If you are a DirecTV or Cox subscriber, you may sync a universal remote to your television using code 1548 or 11548.
These codes are for use with the following Coby television models:
TFTV1022, TFTV1212, TFTV1513, TFTV1514, TFTV1524, TFTV1913, TFTV1923, TFTV2214, TFTV2224, TFTV2617, TFTV3217, TFTV3717, TFTV4717
If the codes do not work, or if you are not a DirecTV or Cox customer, the universal remote control manufacturer is responsible for creating and embedding a Coby-compatible code in the remote control. Please contact your cable carrier or the universal remote control manufacturer for assistance.
Mar 25, 2008 | Televison & Video
Coby TFTV1212 12 in. LCD TV Logo
24 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
