Question about ASUS CROSSHAIR Motherboard
Hi, Hope you can help. I've just fitted a new motherboard to my computer (ASUS crosshair 2 formula). My memory is 2 x 2GB DDR2 running at 800Mhz. Th machine will run fine using either of the sticks, but if I have both installed the machine blue screens after a couple of mins. I have tested both sticks and there are no issues. I have tried to update my BIOS using the EZ Flash utility but my pen drive can't be seen. ANy help or advice would be appreciated. Thanks
    Problem Solver:
  • 13 Answers
Hi. Asus has a great utility that lets you update your bios even in Windows.
http://www.asus.com/product.aspx?P_ID=EIDxaW1Ln3YR9RA2
At the download section select your OS and in Utility section find "ASUS Update V7.14.01 Install Program" This program will automatically update your bios.
As for your Ram issue. Did you try each stick in each ram slots ? If you did and saw no issues, then I am only suspescting of incompability between your Rams.
Posted on Oct 13, 2010
Is 2GB DDR2 PC2-6400 800MHz compatible with ASUS P5GC-MX/1333 if not what is the fastest and correct Ram I can fit;
From ASUS Site:
https://www.asus.com/us/Motherboards/P5GCMX1333/specifications/
2 x DIMM, max. 4GB, DDR2 667/533 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
**When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Apr 01, 2017 | ASUS Computers & Internet
I have 2 DDR2 RAM of 2 GB each but i am unable to install both. Please let me how to install both in D945GCNL intel Motherboard.
Hi ,
your computer is preset to handle so much memory , you need to find out how much it can handle ,you can do this by going online , and google your make and model of computer and read the specs on your computer .....................hope this helps ................good luck Roy ,
Sep 03, 2011 | Intel Motherboard, 945GC, Core 2 Duo,...
Can asus p5gz-mx support 2gb kingston 800mhz ram
Click here to view the Specifications of your computer mainboard.
Unfortunately only 2 x DIMM, max. 2GB, DDR2 533/400 MHz memory modules are supported.
Meaning that it is not possible for the 2gb kingston 800mhz RAM to run, according to the Specs.
Sorry to inform you of this fact!
damnor01
Jan 23, 2011 | ASUS P5GZ-MX Motherboard
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
I need changes my memory 2 pcs @ 1GB DDR1 PC3200 with 2 pcs @ 2GB DDR2 PC6400 in Asus P5VDC-MX Motherboard. please advice. Thank you
Number of Memory Slots: 2×184pin + 2×240pin
Memory Standard: DDR 400/DDR2 533
Maximum Memory Supported:2GB
PC6400(DDR2 800) is not supported by your motherboard. Also max memory is 2GB. PC4200 is the fastest memory you can install. There might be a BIOS update available from ASUS website to increase the speed but you would have to check the site.
Dec 01, 2009 | ASUS P5VDC-MX Motherboard
ASUS P5QL PRO memory problem
This problem occurs because of confliction between RAM memory frequency.
For that you must have 2 RAM with same memory frequency and same company chip .
Then it works fine with 2 RAM.
Let me know if you need further assistance.
Thanks.
Nov 03, 2009 | ASUS P5QL PRO Motherboard
Hi, I want to upgrade my Acer Aspire 5100 memory to DDR2-800Mhz. Can I do it? Will the motherboard bus support it?
Sorry but the specs for this system states the highest possible ram is DDR2-667 with a max of 4 GB ( 2 X 2gb Ram)
May 11, 2009 | Acer Aspire 5100 Notebook
Memory
Hi Shawncue,
This memory will not work with this motherboard, The memory is a DDR2 memory and this motherboard only works with DDR memory
May 07, 2009 | ASUS Computers & Internet
Product comparison
deal 2 is definatly better, go for it
Oct 28, 2008 | Computers & Internet
ASUS CROSSHAIR Motherboard Logo
87 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
