Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
Have a orange band across the top of TV - Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
    Sergeant:
  • 171 Answers
Hi there it sounds like you are starting to have a problem with the LCD chips they are starting to burn out and that is the reason you have this effect and the problem will only get worst with time
you need to replace the OPTICAL BLOCK to fix this problem
check out this link it will help trust me
http://www0.epinions.com/msg/show_~threads/cat_id_~13/id_~9877/forum_id_~127
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Posted on Oct 12, 2010
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
Dark horizontal band at top of Sony KDF - 46E 2000 TV
rca ps2720lv blue is very dim any suggestions
Nov 14, 2009 | Sony Televison & Video
Brownish band across top of screen
Please press the WIDE button on the remote repeatedly to remote the Bands. If the issue persists, you may need to change the Aspect ratio to 4:3 on the Video source that you have connected to the TV. Check the link for more info:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C308757&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=130649210&stateId=0%200%20130647809
Sep 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Banding on screen
Since this TV is still new, it's much faster if you exchange the unit at the place of purchase and get a new one. You can also call Sony at 1-800-345-7669 (SONY) and get it service for free.
Jun 16, 2009 | Sony Televison & Video
Mitsubishi TV CS35313
bad caps in the vertical output and jungle IC section. Check all boards for black runs, leads near/on caps, they leak and eat the copper runs.
Nov 03, 2007 | Televison & Video
There is a band developing
The band is developing across both the top and bottom of the screen it is called cinemascope picture. it is a vertical failure. it is not a major problem. it is on you accrding to cost of repair. it is due to less supply or part failure in vertical section.
Sep 24, 2007 | Philips 32PT5441/37 32" TV
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
