Question about GE Microwave Ovens
Just bought a PEB2060DMBB MICROWAVE and there were no installation instructions included. I am installing the unit in a built-in cabinet and need to know the amount of space needed for exhaust.
  • MBDAN Jun 01, 2008
    tHIS does not answer my question. I need to know how much space is needed behind or around the unit for the exhaust'
  • 1,031 Answers
Check out the link for the full dimension for the exhaust and other consideration
Posted on Jun 01, 2008
  • Starnley Johnwells
    Starnley Johnwells Jun 01, 2008
    you will like 60cm distance off
  • 166 Answers
Hello there.
Please click here for the Installation Guide , Quick Specs and Use and Care Guide .
You need a PDF reader like acrobat reader or foxit reader installed to view these files.
Hope this helps.
Can you provide under cabinet mounting instructions for GE Microwave part WX4-A19?
To mount it under a cabinet, you have to have the under cabinet install kit; you'll find that here: Under Cabinet Mounting Kit WX4 A019 GE Appliances the kit does include instructions. You can't mount it without the kit.
Dec 12, 2015 | GE Microwave Ovens
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
How to remove a built in microwave
Hello karentallett - Typically Frigidaire does not have specific instructions on how to exactly remove a built in microwave. Since it is such a complex unit with multiple parts that it is suggested to handle with caution including the mounting brackets when it was first installed, I would recommend contacting a professional to move forward accurately.
Oct 04, 2012 | Electrolux EMS2487X Convection Microwave...
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
How do I remove oven from under cabinets ?
Refer to the installation instructions.
We have installation instructions that cover or would be close enough for several Sharp models here
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can download GE owner's manuals and installation instructions here.
Apr 18, 2010 | Sharp R-1874 Convection/Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
PEB2060DMBB microwave
who's the maker of that microwave oven. That's a good place to begin this discussion.
Jun 01, 2008 | Microwave Ovens
Just bought a GE MicrowavePEB2060dmbb and there were no installation instructions included. My need is to determine how much exhaust space is needed when the oven is being built into a cabinet.
You should be able to download the installation instructions here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 01, 2008 | GE Microwave Ovens
Removing a built in Jenn-Air Microwave from it cabinet...
First of all, what are the symptoms? Please reply back and I'll be happy to share my thoughts.
Many parts can be accessed without removing the oven from the wall by just removing the control panel.
You need to be sure the cord is unplugged, then you remove the vent grille that runs across the top.
Then you'll see a screw holding the control panel in place. Once that screw is out, you can lift out and out carefully to separate the control panel form the chassis.
If you pull any wires off the control panel, mark and/or photograph them first to be sure you get them ALL back in the right place.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Before you start, we have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa:
While they don't have their installation instructions online, the owner's manual is online here.
Mar 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
241 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
