Question about Franklin Freezer Chef FIM70 Commercial Ice Maker
I have 3 FIM70 ice makers. 2 work fine but the third one makes very thin ice and the cubes it does drop into the bin melt away. It throws off a lot of heat. The air circulation is good so thats not the problem.
  • desa99 Oct 13, 2010
    This is a new machine. Outside of its cabinet , it makes ice but it melts, the machine is constantly working. compared to the other machines I have it puts out a lot of heat,
    The ice maker is new. Is there an air filter that could be clogged? other then the one on the front of the unit. It sat in a dusty environment awhile before it was installed. I don't understand why it throws off so much heat when it is running.
  • 10,865 Answers
Hello. The symptoms you describe indicate that an interior cleaning is in order:
The ice storage bin should be sanitized occasionally. Clean the bin before the ice maker is
used for the first time and reused after stopping for an extended period of time. It is
usually convenient to sanitize the bin after the ice making system has been cleaned and
the storage bin is empty.
1. Disconnect power to the unit.
2. Open the door and with a clean cloth, wipe down the interior with a sanitizing
solution made of 1 ounce of household bleach or chlorine and 2 gallons of hot water
(95? to 115?F).
3. Rinse thoroughly with clear water. The waste water will be drained off through the
drainpipe.
4. Reconnect power to the unit.
Here is the owner manual in case you do not have one:
http://dl.owneriq.net/2/294a2d80-17c5-43dd-ae8c-800510870f66.pdf
Joe
Posted on Oct 14, 2010
  • 2,427 Answers
Well it only drops into the bin after the Cubes reach a certin density,, The thin Ice Cubes Will account for this.. The only Thing I can think Of is that it isnt getting cold enough Or the Tray mixer is a defective.. You can try adjusting the temperature (if Possible) or you can use a thermometer to check the temp difference between the working and no working onesto verify my theory is correct.. If you have warranty I'd use If ,, If not ,, Variables that affect temperature
1.) freon pressure
2.) Thermostat
Check Those..
Posted on Oct 13, 2010
  • 760 Answers
These ice makers should be cleaned occasionally. I don't mean just pressing the clean button, although that is important too. If it isn't spraying enough water, then it won't form a thick enough sheet of ice. Here is a link to a manual. Buy some ice maker cleaner and follow the directions to clean it. Check the flow from the sprayer arm. You can compare water flow to one of your operating machines. Here is link to a manual.
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-Appliance-Site/Sites-CompactAppliance_Primary/default/v1286551031332/pdf/ownersmanuals/Franklin/FIM70-90-120.pdf
Why would a Franklin Chef FIM70 ice cubes melt before next ice drops
Its seems low refrigerant issue kindly contact with your local repair man to refill refrigerant gas
Jul 22, 2016 | Franklin Freezer Chef FIM70 Commercial Ice...
Franklin chef ice maker fim70 finished running cleaning cycle. have cleaned plugs, lines, on rear and sprayer inside bin. water continues to run, ice forms on top (w/ frost). Ice never drops.
Hello
Ice may jam up in an ice dam and close off the chute. Shove the ice scoop up into the chute with a fair amount of force to break up the ice dam. Chunks of ice should fall into the bin, followed by a shower of ice cubes.
Jun 21, 2011 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Franklin FIM 70 Keeps freezing up and now stopped freezing totaly
throw it away...i have the same problem. the company is out of business and no parts available.
Feb 20, 2010 | Franklin Freezer Chef FIM70 Commercial Ice...
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Have a comercial ice machine ,dont know how to hook up!
You gonna have a drain for the reservoir to clean the unit and a drain for the ice bin and then a connection for inlet water. The water valve is the key. Look for it.
Aug 27, 2009 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice Machine FIM600 Ice is making too big
remove front cover to view control panel. there is a cube size adjustment there. use a small screwdriver and turn it counterclockwise to make the cubes smaller
Jan 07, 2009 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice maker leaks into the ice storage bin
turn off the power to the appliance and apply a hairdryer to the ice maker compartment for about 2 mins , worked for me.
Jan 11, 2008 | Freezers
Franklin Freezer Chef FIM70 Commercial Ice Maker Logo
149 people viewed this question
Top Franklin Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
mike cooper
Are you a Franklin Freezer Expert? Answer questions, earn points and help others
