Question about Hitachi 3 - 1/2" Full Roundhead Framing Nailer
How do i set the depth - Hitachi 3 - 1/2" Full Roundhead Framing Nailer
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
What model do you have. I an older NR83A2 with now adjuster welded a nut to the foot/shoe you depress to fire and installed a screw/bolt you can use to adjust depth. I used a bolt 1/4-20 with dead down as to limit damage to material your nailing in to (fence boards / siding). Before I used to lower the air pressure to the gun via the compressors regulator output. Hope this helps
Posted on Nov 17, 2015
    Problem Solver:
  • 5 Answers
I have a older Hitachi 3 1/2 full roundhead nailer and on my there is a button on the front below the head at the end of the nails that you push sideways and hold and slide the nail gun tip up or down. There should be grooves across the front of the tip.
Posted on Oct 12, 2010
Why depth flashing
No depth reading or depth beyond setting of range. Also check connection of head to transducer
Aug 16, 2014 | Raymarine ST70 Depth Transducer Pod ()
Tip
Depth of field is the characteristic of how much of, or how deeply, the...
Depth of field is the characteristic of how much of, or how deeply, the photograph is in focus. If the main subject is in focus but the foreground and background are blurred, the photo is said to have a shallow depth of field. if most of the photo is in focus, including the foreground and background, the photo is said to have a wide depth of field.
Depth of field is controlled by the aperture setting:
- A wide aperture setting (indicated by a low f-stop number) will provide shallow depth of field, resulting in the main subject being in focus and the foreground and background being blurry. This setting is particularly useful when taking portraits or when using a macro lens.
- A narrow aperture setting (indicated by a higher f-stop number) will provide wider depth of field, resulting in the entire photo being in focus. This setting is particularly useful when taking landscape or wide-angle photographs.
The photographs below are examples of how the same subject will photograph using different aperture settings. Note that as the aperture closes, which will allow less light to reach the image sensor, the shutter speed gets faster to produce the appropriate exposure.
I think you have got a general idea about depth filed. If you have further questions, you can ask me directly. http://www.fixya.com/users/shajanrs
depth of field - what is depth field - how depth field affects picture - how to adjust depth field - DEPTH FIELD - depthfield - DEPTHFIELD
on Jan 08, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Bostich RN-46 seems to be over sinking the nails even went set to low depth
Adjust the air pressure on the regulator to about 90 lbs. or lower. maybe higher than 90 but that should help you set the depth.
Jun 05, 2014 | Stanley Factory Reconditioned Bostitch...
Bn125a nailer not sinking nails all the way
The depth to which a fastener is driven is controlled by the depth adjustment
knob (A) Fig. 19 below. The depth of drive is factory adjusted to a nomimal setting.
Test fire a fastener and check depth. If
a change is desired, rotate the
adjustment knob (A) Fig. 19: the
adjustment knob has detents every 1/4
turn. Rotate the knob clockwise (see
Fig. 19), to increase the depth of drive,
rotate the knob counterclockwise to
decrease the depth of drive. Test fire
another fastener and check depth.
Repeat as necessary to achieve
desired results. The amount of air pressure required will vary depending on the
size of the fastener and the material being fastened. Experiment with the air
pressure setting to determine the lowest setting that will consistently perform
the job at hand. Air pressure in excess of that required can cause premature
wear and/or damage to the tool.
Good Luck
Nov 26, 2010 | Porter Cable Cable BN125A Factory -...
I have dewalt dc618, nail doesn't goes all the way in, please help?
Below find information on how to adjust for depth, however if you have already made adjustment then check for broken tip on driver blade. The blade is not expensive and available from dewalt service center.
Please note the following from manual:
Adjusting Depth
The depth that the fastener is driven can be adjusted using
the depth adjustment wheel (C) on the side of the tool.
WARNING: To reduce risk of serious injury from
accidental actuation when attempting to adjust depth,
ALWAYS:
• Remove battery pack.
• Engage contact trip lock-off.
• Avoid contact with trigger during adjustments.
1. To drive the nail shallower, rotate the depth adjustment
wheel (C). There are twelve depth settings, 1 being the
shallowest and 6 being the deepest.
2. To sink a nail deeper, rotate the depth adjustment
wheel (C) to a higher setting.
Sep 08, 2010 | Dewalt DC618KA Angled Nailer Kit
How do you set the depth on a Bostitch N57c coil nailer besides lowering the air pressure
Hello. The only way to set the depth is to lower or raise the air pressure. The rn175, however does have a depth setting feature which you may find useful for your app. http://www.protoolreviews.com/reviews/air-tools/bosch-roofing-nailer-rn175
Jul 01, 2010 | Stanley Bostitch Coil Framing Nailer
Blade Depth
Aren't there two handcrank wheels on the sides of the saw? One is for blade angle of cut, the other is for depth of cut.
Jun 07, 2010 | Craftsman 10" Table Saw
Furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Aug 01, 2009 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
My depth finder flashes 00.0 I can not get it to work
The shallow water sensitivity adjustment is set too far to an extreem. Center the adjustment, then recalibrate at the dock.
May 24, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
How set the colour depth of the screen
you can set the color depth in your display properties->settings->color quality select 32 bit. if still don't work. reinstall your video card driver.
Jun 29, 2008 | HP Computers & Internet
Hitachi 3 - 1/2" Full Roundhead Framing Nailer Logo
99 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
