Question about KWorld (KW-L883D) (KWL883D) Video Capture
Tengo un dvd maker usb 2.0 kworld, quiero pasar videos de una videocámara al pc y después de capturar el video, lo reproduzco pero no se pasó el sonido. He intentado cambiar los formatos de entrada de audio y parece que todo lo demás está correcto, ¿qué puedo hacer? no me sirve de nada el video sin el audio...gracias!
5 Suggested Answers
SOURCE: GOOD VIDEO BUT NO SOUND
I too had this problem and it was because the 'line in' volume was set to zero. I had connected the mini-jack on the DVD Maker to a blue input socket at the back of my computer. I found this setting by right-clicking 'Volume' icon in the system tray, and selected 'Open Volume Control' .When I opened the volume control panel, I saw all input and output sockets and was able to adjust 'Rear Blue In' and it now works fine. I am running Window XP Home.
Posted on Jun 29, 2009
SmartAviator
  • 449 Answers
SOURCE: How do I conndect my VHS VIDEO RECORDER to the
Check the users manual of both products. If there is an option for it, it will be mentioned in the user manuals. (ehteshamhusain@gmail.com)
Posted on Jul 20, 2009
  • 1027 Answers
SOURCE: I have no sound when trying to copy a vhs video to
The sound enters the PC through the 'line' input audio connection. In the audio panel controls, ensure that the line input is enabled, and the gain is not zero.
Posted on Sep 09, 2009
SOURCE: audio does not record when
1.Download and install k-lite codec pack(full version) > http://www.free-codecs.com/k_lite_codec_pack_download.htm
2.Click the link below to download DVD MAKER USB 2.0 Software. driver/win7/Edit/V5.9.721.812_DVD_%20Maker_USB2.0.zip
Posted on Aug 31, 2011
Mi video camara es canon Dc210 DVDcamcoder no acepta los DVD que le pongo de ninguna que puedo hacer
El manual dice que algunos discos no vas a funcionar con la cámara, pero por supuesto no hay nada en el sitio de eso.
Yo sabía acerca de un problema similar, ya que estaba tratando con los discos DVD + RW. He encontrado algo la solución en la web de Canon: DVD-R/RW y DVD + R / RW son similares, pero en general los formatos no interchangable.
Las videocámaras Canon DVD sólo utilice discos DVD-R/RW. DVD-R/RW y DVD + R / RW son similares, pero en general, los formatos no interchangable. Las videocámaras Canon DVD sólo uso * DVD-R/RW o DVD-R DL (DC10, DC20, DC100, DC40 y no son compatibles con discos DVD-R DL). Si un disco DVD + R / RW se carga en una videocámara Canon DVD de la videocámara mostrará un mensaje "Error de Disco" después de que intenta leer el disco.
* Discos DVD-R de doble cara también se puede utilizar sin embargo, cada lado deberá ser inicializado antes de su uso.
Espero que esto le sea de ayuda; recuerde calificar esta repuesta. Suerte.
Sep 26, 2011 | Canon DC210 DVD Camcorder
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Porque cuando tomo una foto de cerca sale borrosa la imagen
Eso sucede porque tu c?mara no ha podido enfocar la imagen, por lo general solo se necesita presionar levemente el bot?n para que el sistema de autofoco haga su trabajo y luego terminar de presionar el bot?n para capturar la imagen.
Otra causa puede ser que est?s utilizando un modo de telefoto o un enfoque largo y al tomar la imagen esto provoca que pierdas definici?n.
Jun 02, 2011 | Video Game Consoles & Games
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
No tengo el cd y quiero intalar una camara logitech 961306
hola raul....
tienes que ir al web de logitech a esta página para elegir tu país.
una vez que has entrado en el web... haz un clic en el enlace para 'Asistencia' (arriba del todo en letra muy pequeñita). en la parte 'Buscar por nombre' elija cameras web... y debajo el modelo, y haz un clic en la flecha.
en la página siguiente, haz un clic en descargas y después en tu sistema operativa y después en el archivo....
Muy Importante:
para elegir el archivo necesitas saber si tu sistem operativa es de 32 o 64 bits... lo puedes averiguar haciendo un clic derecho en el icono de 'Mi Pc' (en XP) o 'Equipo' (en Vista) y seleccionando propiedades del menú emergente.
espero que esto te sirve de ayuda, y avisame si tienes alguna pregunta mas!
bru*
Feb 17, 2009 | Logitech QuickCam Messenger Web Camera
Problema tarjeta sabrent
Hola, que tal yo tengo un problema también con la TV Tuner de Sabrent, pero en mi lap tiene Windows Vista y no me detecta audio.
¿Cómo le hiciste tu para que detectara audio al sintonizar la TV y capturar video?
roy_villafuente2510@hotmail.com
Dec 02, 2008 | Sabrent TV Tuner / Video Capture Box USB...
GR-DX75US
Hola Lucio
Yo sot de Argentina y me pasó lo mismo que a vos, llamé a representante en Argentina y me dicen que ellos no lo pueden arreglar porque la camara fue comprada afuera de Argentina, esto es una locura ya que en todo el mundo las están arreglando gratis. Decime como hiciste si es que lograste solucionar el problema
Saludos
Nov 15, 2007 | JVC Cybercam GR-DX75 Mini DV Digital...
No se ve el video en mi TV
yo tambien quisiera los codigos me harian un mega favor, les dejo mi correo manuelgutierreznevarez@hotmail.com de ante mano gracias
Nov 24, 2006 | Yahoo YHT-650 System
KWorld (KW-L883D) (KWL883D) Video Capture Logo
71 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Ruben Balisbis
Ruben Balisbis
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
