I am working on a Potain self erect crane type: IGO 22 28m 1800kg. the electrical diagram is missing. and the crane has in it programmable devices such as Hetronic component and ATV 31 that needs program settings, the hetronic has a display screen that comes up with a massage DEFAULT 0005, 0018, 0003. and when you press enter for assistance mode the crane operates on only one speed, but the trolley, hoisting and swinging.
SOURCE: setting date/time display
First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
Posted on Apr 19, 2007
SOURCE: SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Posted on Aug 10, 2008
  • 3594 Answers
SOURCE: Canon Typestar 6 operation
I believe there is a mode key. Press it until np appears in the display.
DickyO
Posted on Sep 03, 2008
SOURCE: setting up speed dial numbers
I HAVE THE ANSWER YEAH!!!!!
I just started working at my job and we call the same labs everyday and I really needed this speed dial to work.
These are the steps; I hope it works for you.
1.Do not lift the handset.
2.Press Redial
3.Put in the speed dial # example 60
4.Put the entire phone # inc. area code.
5.Press Redial
It should be stored.
Have a great day.
Posted on Jan 29, 2009
SOURCE: Tap the screen to set up your windows mobile based
Tap the screen to set up your windows mobile based device this massage is coming. How to solve it when the touchscreen is not working?
Posted on Mar 02, 2010
What is the vertical ic number of onida igo ultraslim CI21JST200B colour tv ?
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Jun 10, 2016 | Televison & Video
How to wire No. 165 Electromagetic crane
Service diagrams are available on the Lionel web site.
Jan 23, 2016 | Crafts & Hobbies
Crane hi-4n single fire ignition installed in my 1995 xlh 1200 sportster Harley davidson .now tacho doesn't work properly
Contact Crane for wiring diagram - although they should have supplied one with the product. You may not have connected the tach wire to the correct output from the ignition module.
Aug 25, 2014 | Harley Davidson Motorcycles
I miss igo tv 4 digital password
eanike igo tv ude company passwerd venam
Nov 13, 2011 | Televison & Video
Hello there. just a question about my telescope. it looks like the baska . all it has is a model number 70060. view finder is upside down ( apparently that is normal). but when i look through the main...
You are using an erecting diagonal mirror between eyepiece and the scope. This flips the image (normally inverted as you realise) upright, but does not correct the reversal from side to side. These are often supplied with astronomical scopes more for ease of looking through the scope without craning one's neck upwards, rather than for the purpose of erecting the image.
There are other types of erectors that will fully erect the image if it bothers you, but astronomical telescopes normally are used without concern for such conventions, as the erecting lenses or prisms absorb light and introduce aberrations or reflections. If you wish to use the telescope for terrestrial work, you would probably be better off with a "spotting scope" which will be fully corrected for image orientation.
Jan 22, 2011 | Barska Optics Barska AE10094 - 70060, 525x...
I want schematic diagram of igo 14 inch tv
igo protbile tv igo problem set is stand by microchip ic
Oct 15, 2010 | Televison & Video
Missing information on a hollywood skill crane
Hi, did you ever get the manual? I am in need of one too. Thank you.
Nov 12, 2009 | Kitchen Appliances - Others
Megallan 3250 car chrager tip is missing
I went out and purchased an iGo charger. I was able to purchase the charger at a Radio Shack store, but in order to get the proper tip, I had to go to the manufacturer web site and order from there. I'm sure that you could order a new charger from Magellan, but it might be more expensive to do so. The iGo is capable of taking multiple tips for multiple devices. I hope that this helps.
Nov 06, 2009 | Magellan RoadMate 360 GPS Receiver
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
