Question about Maytag PYE2300AY Electric Dryer
Bottom face of dryer excessively hot
While running the dryer the bottom face of the dryer, below the door, has been getting very hot. Otherwise dryer is working fine.
  • remotctrl Jun 02, 2008
    It doesn't just get "warm". It has been getting excessively hot, to the point where you can not touch the front of dryer. If you were to touch the front with your foot the metal gives like it is very soft from the excessive heat. At the back side bottom of dryer where vent comes out, there is a large area of moisture on the floor
    Scholar:
  • 116 Answers
That is where the fan is located, hot air is drawn from the hearer at the rear of the drum, through the drum then through the fluf filter at the front (inside the front edge) and then down the front panel and to the fan, then via a duct to the rear. So would get warm at this part.
Would check that the external ducting is clear and not kinked, flexible plastic or foil ducts should not be used for these machines ie fixed ducting only.
Mark
Posted on Jun 01, 2008
  • Mark Hughes
    Mark Hughes Jun 03, 2008
    Check the ducting, run the dryer without the ducting fitted and see if the problem persists.
    If temperature is then normal, check ducting for blockage.
    If not then check heater stat.
    hope this helps
  • Mark Hughes
    Check also for air flow from the rear duck/vent when running, if there is no air flow then check the fan impeller (these are usually plastic and wear on the spindle preventing air flow.
    If the drum is rotating the motor is ok as the drum and fan impeller are generally run from the same motor.
Electric lift stopped 2/3 way up. There was also a burning smell. Won't work at all. Is there a manual overide?
Hello;
My name is Peter. I am a retired field service appliance technician.
There is no manual override on your dryer. Which is a good thing.
You do not want to run your dryer at this point.
The burning smell is burning lint. Your dryer is plugged up with lint. This is a dangerous situation. You could burn down your home.
Your dryer will not run because the dryer fan will shut down if the air flow is obstructed.
You have a hot air exhaust manifold where the hot air goes into a round bottom inlet up to a expanded hot air distribution headed into the dryer. This is usually plugged up.
This may also have caused the fuse to blow, a operating switch or high temperature limit switch to fail.
Go into the following website and put in your model number. You will get diagrams and component part numbers. Your model number is located on a label either on the face of the dryer when you open the door or on the side of the door.
Water Filters Lawn Garden Appliance Parts
Mar 10, 2016 | Dryers
Started running hot,replaced thermostat and still runs hot.Top radiator hose is hot bottom is cold.
Did you put the thermostat in backwards? If you did, it wont open when hot. Thermostats look pretty much the same - with some minor variations. It's important to note the the side with the spring should be facing the (hot) engine and the other side facing the (cool) radiator as shown in the image below. If the spring side doesn't get hot - it won't open to let hot water from the engine flow to the radiator for proper cooling.
Aug 10, 2015 | Cars & Trucks
Lint is collecting mainly on bottom and more on one side of lint catcher
Hello;
It is not uncommon for drier vents to go up with a vertical section, but usually the is a horizontal run coming off the back od the dryer to prevent the lint from coming back into the dryer.
You did not provide a model number which should be on a label on the face of the dryer when you open the door.
You probably have a hot air distribution manifold behind your dryer. It is easily removed. It has about 6 screws holding it on and pulls straight off. In the bottom part of the manifold is where you get plugged up with dry harden lint. You need to clean this out and maintain a strong air flow.
May 23, 2015 | Dryers
I am getting ice around the door and the bottom of the freezer
This is usually due to a plugged up drain. If you look behind the food and shelves near the bottom you will see a small hole facing down. This can be flushed with hot water using a turkey baster until the water runs free
Apr 16, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
Water accumulates in freezer bottom and of course frezzes. if we don't break up and remove the ice, water will leak out the door. best guess on the model below. The back panel states "R134a"
134a is the type of freon used. There is a defrost drain hole at the very bottom of the freezer usally below the back panel. It has a tube that runs underneath behind the back bottom of freezer section. It can get stopped up with slugg that keeps the water from getting to the defrost water pan. The water in the tube freezes and the water then runs out the front of freezer being it has no exit. . hot water or a hair dryer gun. If you have means to blow hole out after ice is melted will do a better job. Blowing warm water down hole through tube with mouth will knock ice out quickly but be very careful. also this ewill remove any trash build up in drain hole.
Mar 01, 2010 | Kenmore 57029 Side by Side Refrigerator
We have a Frigidar Gallery dryer. The across the
they tend to get hot but excessive heat I would contact a reputable appliance repair and ask them also how old is dryer I do not know if they are still being made Gen.Motors sold them off 30 yrs ago
Dec 18, 2009 | Dryers
Where do i locate the electronic ignitor on a kenmore gas dryer? it tumbles but i don't hear the gas ignite and it doesn't get hot and there is gas in the tank.
it is in the bottom front under the lower door below dryer door if it is not igniting then call a gas repair to fix it you do not want to work on any gas appliance unless you know what you are doing
Dec 13, 2009 | Kenmore Dryers
WHY IS THERE ALWAYS ICE ON THE BOTTOM OF THE FREEZER.IT GETS TO BE SO THICK THAT THE DOOR DOESN'T SEAL?
You have a frozen drain. Remove the cover on the bottom back and locate the drain tube and thaw it with a hair dryer. Find the drain inside the fridge and run hot water thru it until it opens.
Oct 26, 2009 | LG LRBN22510WW Bottom Freezer Refrigerator
Dryer will not get hot dryer will come on and run but it will not get hot what cvould be the problem
CHECK FOR 240VOLTS AT THE OUTLET. THE DRYER WILL RUN WITH ONLY ONE SIDE OF THE 240VOLT CIRCUIT BUT THE DRYER WON'T HEAT.
IF YOU OWN A METER AND KNOW HOW TO USE IT, TAKE THE BACK PANEL OFF OF THE DRYER AND FIND THE HEATER ON THE RIGHT SIDE FACING THE BACK OF THE DRYER(WHIRLPOOL AND KENMORE DRYERS).
CHECK FOR 240 VOLTS AT THE TWO TERMINALS OF THE HEATER. IT WILL BE THE TWO TERMINALS LOWEST TO THE GROUND AND HAS TWO RED WIRES ATTACHED TO THEM. IF NO 240VOLTS, BACK TRACK THROUGH THE CIRCUIT AND CHECK EACH ITEM YOU COME TO. IF YOU FIND 240VOLTS, THAT IS THE BAD PART.
FOR MAYTAG PRODUCTS, REMOVE TWO SCREWS FROM THE BOTTOM FRONT OF THE DRYER AND SWING THE BOTTOM OUT UNTIL THE CLIPS DISENGAGE FROM THE TOP. SET IT ASIDE. THE HEATER IS LOCATED IN A TUBE AT THE BOTTOM RIGHT OF THE INSIDE. CHECK IT THE SAME WAY.
Apr 08, 2008 | Dryers
Bosch classixx refridgerator
the evaporator is probably iced up and hence poor air flow. (i am assuming it is a frost-free type). switch off and leave for 24 hours with door open is the easy cure. otherwise, remove the back inside panel of the freezer and melt off the excess ice with a hairdryer used carefully
Jun 02, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Maytag PYE2300AY Electric Dryer Logo
53 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
