Question about KitchenAid KUDR01TJ Dishwasher
Need to replace door latch. Do I access it by removing all the screws on the inside door panel? or something else? thanks
    Problem Solver:
  • 12 Answers
Only the top half screw's would be enough, the pannel should popout then...
Posted on Oct 12, 2010
  • Richard Robb
    Richard Robb Oct 12, 2010
    oops wrong post... sory... in this case you would have to remove them all and then the outside pannel to access the latch...
  • jzalte Oct 12, 2010
    Thanks. You were right the first time.
How do i take off the inside drivers door panel on a 2005 dodge caravan
Hi Roberta, here's the instructions on how to remove your door panel. I have to wonder though on why you are removing it, my guess is you window doesn't roll up or down and your replacing the regulator. Any way here goes.
REMOVAL
  1. Remove the plug and remove screw attaching door pull cup to inner door panel.
  2. Remove switch bezel and disconnect power window/memory switch.
  3. Remove screws attaching trim panel to door from below map pocket.
  4. If equipped, remove window crank. (Refer to 23 - BODY/DOOR - FRONT/WINDOW CRANK - REMOVAL)
  5. Remove screw holding door trim to door panel from behind inside latch release handle .
  6. Disengage clips attaching door trim to door frame around perimeter of panel.
  7. Lift trim panel upward to disengage flange from inner belt molding at top of door.
  8. Tilt top of trim panel away from door to gain access to latch linkage.
  9. Disengage clip attaching linkage rod to inside latch release handle (INSIDE DOOR HANDLE LINKAGE).
  10. Separate linkage rod from latch handle.
  11. Disconnect the power door switch, courtesy lamp electrical connectors.
  12. Remove front door trim panel from vehicle.
Hope this helps and have an awesome day Roberta!
May 21, 2014 | 2005 Dodge Grand Caravan
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
How to remove door panel on 2003 grand caravan
  2. Remove the switch bezel and then disconnect the power window-memory switch.
  3. Now you need to remove the screws attaching the trim panel to the door from below map pocket.
  4. If you have a window crank remove this now.
  5. Remove the screw holding the door trim to the door panel from behind -inside latch release handle .
  6. Now disengage the clips attaching the door trim to the door frame around the outside of the panel.
  7. Lift the trim panel upward to disengage the flange from the inner belt molding at the top of the door.
  8. Now tilt the top of trim panel away from door to gain access to the linkage on the latch.
  9. Now you need to disengage the clip that attaches the linkage rod to the inside latch release handle - this is the inside door handle linkage.
  10. Now just separate the linkage rod from the latch handle.
  11. Now you disconnect the power door switch and the courtesy lamp connectors.
  12. Now you can remove the door trim panel up and out.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 23, 2011 | 2003 Dodge Caravan
What does dL F mean
Hi
Thanks for using FixYa. Error "dlf" means a door latch failure. This means that you'll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it's unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When i press start, door won't lock. code f-dl
Hi
Thanks
Rylee
How do i remove the driver's inside panel door? My electric button panel for windows and locks isn't moving.
Like reference guide, check this procedure to Removal & Installation / Door Lock Motor...
The door lock motor is integral with the door latch. If the door lock motor is found to be defective, the entire door latch must be replaced.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Roll the door glass down.
  3. Disengage the 2 clips attaching the speaker grille to the door trim panel. (They are at the front of the grille, one near the top, and the other one at the bottom).
  4. Remove the 3 large washer-headed screws surrounding the speaker.
    Fig. Fastener location for the door lower trim panel
  5. Remove the access cover at the front of the door trim panel. Remove by prying at its rear edge.
  6. Remove the red courtesy reflector from the lower tail of door. Disengage by prying at the screwdriver notch at the bottom of the reflector.
  7. Remove the flag trim panel from the door by prying it off at the 2 attachment clip points.
  8. Remove the 7 screws attaching the door trim panel to door:
    1. One screw is located at the lower rear screw pocket.
    2. Three screws are located along the bottom of the door.
    3. One screw is located inside the handle opening.
    4. One screw is located at the upper front.
    5. One screw is in the pull cup.
  9. Disengage the 2 hidden clips attaching the rear of the trim panel; pry them off at the 2 attachment clip points.
  10. Lift the trim panel upward and away from the door, disengage the trim panel from the upper retainer channel.
  11. Disengage the clip attaching the latch linkage to back door handle.
  12. Disconnect the electrical connectors as necessary, including the lower foot light, if equipped.
  13. Remove the door trim panel from the door.
  14. Remove the water shield (water dam) from the inside of the door.
    Fig. Remove the flag trim panel, door trim access cover, inside remote handle, and power door lock switch
  15. Raise the door glass.
  16. Remove the bolt and nut for the rear glass run channel and position the channel aside.
  17. Disconnect the lock rod from the lock button bellcrank.
  18. Disengage the lock and latch rods from the clips on the inner door panel.
  19. Disconnect the lock and latch rods from the outside door handle and the key cylinder at the door latch.
  20. Disconnect the wire connector from the power door lock motor.
  21. Remove the screws attaching the door latch to the door end frame.
  22. Remove the door latch and the power door lock motor from the vehicle.
    Fig. Expanded view of the door lock, latch, and linkage
    Fig. View of the door lock button, latch rod, lock rod, and door latch
Hope helps (remember rated this).
Jun 26, 2010 | 2000 Chrysler Sebring
Driver door wont open
buy new door latch need to take apart the door might have to take it to a body shop
Nov 03, 2009 | 1993 Audi 90
The front passenger door will open from the inside but not from the outside.
Requires removing inside panel to gain access to latching mechanism. Most likely a part has broken. Make sure window is raised. Examine all four sides of inner door panel. Look for screws and or screw caps. Remove all screws including door handle, power window and remote mirror controls. Gently pry bottom edge of panel away from door while feeling for resistance (be certain all screws are removed). When inner panel is released, raise panel up and remove. Inspect outer door and inner door latch to determine malfunction (working both controls one at a time). Replace defective parts from dealer or junk yard. Reinstall is reverse.
Jul 09, 2009 | 1992 Buick Park Avenue
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
You'll need to manually unlock it.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore Washing Machines
KitchenAid KUDR01TJ Dishwasher Logo
120 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
