Question about Vizio VO37LHDTV10A 37 in. LCD TV
Where is the backlight inverter located on my VO37LHDTV10A
  • 11,361 Answers
It should be under the holed metal shiled, the inverter baord looks like this: http://www.shopjimmy.com/lg-6632l-0504a-backlight-inverter.htm
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Oct 12, 2010
VO37L HDTV10A backlight on, get sound, no picture
TV sets that have been exposed to significant surges can have multiple boards that are damaged. If the backlights are indeed firing, and you get no picture, you may have a problem with the T-Con board, assuming the main board is working properly. This is exactly why I steer people away from repairing sets that have been hit with large surges. In most cases it will be cheaper to buy new sets vs. repair them.
Jan 17, 2013 | Vizio VO37LHDTV10A 37 in. LCD TV
Hp g5000 sreen does not light up as usal, i can see a the start up when i shine a torch at the sreen, what do i need to do to get working.
An LCD screen cannot produce enough light by itself. It needs an additional source of light.
A Backlight is used as the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to the Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
The LCD screen is a composite of layers, surrounded by a thin metal frame that resembles a picture frame.
To one side of the LCD screen layers, and under the frame is usually where the Backlight is mounted.
[Note* Two Backlights are used in some models]
Replacing a Backlight is more labor intensive than replacing an Inverter.
Due to this, and the cost, the LCD screen itself is replaced as a unit most of the time, when it comes to Backlight replacement.
Example of a replacement LCD screen for the HP G5000 series of Notebook PC's,
https://www.screentekinc.com/HP_G5000_Series--15.4-inch--1280x800-wxga-laptop-lcd-screen.shtml
[Note* Stating HP G5000 is just stating the model series. When buying replacement parts the EXACT Model Number should be used. This information is located on the bottom of the laptop, in a white Service Tag.
When replacing an LCD screen, the model number of the replacement LCD screen should be matched to the existing LCD screen's Model Number.
Inverters and LCD screens are matched together. Make sure you get the correct part]
An Inverter is used to provide power from the laptop to the LCD screen, and to the Backlight.
Note* 90 Percent of the time the problem is a bad Inverter.
Example of an Inverter for an HP G5000 series notebook PC,
http://www.zlectronic.com/product/INVERTER-FOR-HP-DAC-07B035-DAC-09B017-DV5000-G5000.html
The LCD screen, Top Cover, Display Bezel, Inverter, Backlight, and various screws, make up the Display Assembly.
The Display Bezel made of plastic surrounding the LCD screen, and in front of the LCD screen is removable.
Behind it is easy access to the Inverter.
The Inverter is approximately 4 inches long, and the width of a No.1 pencil.
Usually located at the bottom of the LCD screen, and right behind the Bezel.
This article shows replacing an Inverter and LCD screen on a Compaq Presario v2000 series Notebook PC,
http://www.insidemylaptop.com/replace-lcd-screen-inverter-compaq-presario-v2000-laptop/
This pictorial guide is not for the HP G5000 series Notebook PC, but the models are very similar when it comes to Inverter replacement.
The above link is to show you what is involved.
Please post questions in a Comment.
Regards,
joecoolvette
Apr 03, 2011 | Computers & Internet
My audio works fine but no picture.I was told to check the fuses but dont know where the fuses are located at
The slow-blow white fuse is located nearest the point of where the power cord of the tv first contacts the power supply (middle-board, usually)
However, I would suspect the backlight inverter is faulty:
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the ps_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
Hope this helps! Please rate!
Mar 07, 2011 | Televison & Video
Glenngoodwin@verizon.net
what problem are u having? is it no video, led lights, if so then the inverter board is bad.
Jan 14, 2011 | Vizio VO37LHDTV10A 37 in. LCD TV
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
My laptop screen went black every thing is working but i cant see anything what might be the problem
hold the unit slihtly to a light if you can see the icons dimly on the screen then your screen has gone into freeze mode if you cant see the icons then your screen is probly blown to reset the screen from frozen it needs to be un plugged from the motherboard and plugged back in the plug is located under the panal above the keys
best luck
Oct 14, 2010 | Computers & Internet
Back light inverter board is located on left side if you see tv rear, usually its covered with some shield.
Oct 12, 2010 | Vizio VO37LHDTV10A 37 in. LCD TV
My Vizio works for about 5 minutes then shuts off. It will not go back on. There is no clicking sounds either when i press the power button. The Vizio logo lights up and thats it, no sound no picture no...
First place to look will be the power supply and the backlight inverter module, look for poor solder joints, loose connection, etc.
Jul 21, 2010 | Vizio VO37LHDTV10A 37 in. LCD TV
I have a Fujitsu Siemens Lifebook s7020 with no backlight. The display is showing everything but it's hard to see because there's no backlight. Everything is also fine with an external screen. I have a...
The Inverter board must be tested and eventually replaced. The inverter is the small board located at the base of display. This is connected to one side to the backlight lamp, to which supplies AC high voltage, and on the other side to motherboard, where receives DC voltage.
Inverter contacts to otherboard and to lamp must be tested , using a multimeter to read volts. The inverter is an AC board, and for safety reason the test must be done by a trained repairer.
If the inverter is OK check the contacts to motherboard and wiring harness to motherboard..
Also ensure that light is not just dimmer because energy save mode is on, or because the laptop is running on batteries.
Sep 07, 2009 | Fujitsu Siemens LifeBook S7020 Notebook
Vizio VO37LHDTV10A 37 in. LCD TV Logo
360 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
