Question about Casio Exilim EXZ75 Digital Camera
Where is memory card slot on Exilim EX-275? I can't find any opening on the case.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
On the bottom, toward the right side of the camera (as viewed from the back). There's a single cover there that opens to reveal both the battery slot and the card slot.
Posted on Oct 13, 2010
Exilim camera memory full when few pictures taken
Have you fitted a memory card?
The camera will only take a few photos using its own memory.
It takes: SD Memory Card, SDHC Memory Card , SDXC Memory Cards.
If you have fitted a memory card it may be faulty and you will need to buy another.
Jul 27, 2014 | Casio Exilim Ex-h30bk Ex-h30 Black Digital...
Every time I take a picture it says card error even bought a new card
What type and size memory card? The EX-Z50 works with MMC and SD cards. While higher-capacity SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Jan 09, 2013 | Casio Exilim EX-Z50 Digital Camera
I have a casio ex z500. I bought a 8gb sdhc card and it didn't work, so I downloaded the 1.02 version. It takes pictures but now when I insert the card in the memory slot on my computer, the computer is...
The EX-Z500 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with this camera.
Feb 26, 2011 | Casio Exilim EX-Z500 Digital Camera
Casio exilim ex-80 always shows SD card as locked
the SD card should have a small switch on the upper left side it slides from lock to unlock if this doesnt work Look in the card slot - there may be a small bit of plastic sticking out over where the card's locking switch would fit when the card's inserted.
Oct 25, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
My camera is locking my memory card. I slide the lever on the memory card to unlocked, which is down, and when i insert it in the phone and push it down to lock it in, it pushes the 'lock' on the memory...
I have had a similar problem with flimsy lock tabs. I solved it by placing a small amount of scotch tape over the tab - starting near the connection pads, over the tab to the back edge of the card. There's usually not a whole lot of extra room in the slot, so insert carefully and remove portions of tape as needed.
Worst case scenario - if you never use the locking tab (I never do) you could place a small dab of super glue to hold it in place. Let it "set up" before reinserting - you don't want the tab to move an be held on the lock position.
Sep 18, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Casio Exilim ex-z80 pink camera saying memory card is blocked.
If you say memory card error, I ever met this problem too but, in the digital camera canon ixus 400. The solution for this problem is disassamble the camera until you find the card memory slot. Clean the memory card slot with brush. If you think is not enough, you can use liquid like "thiner" ( I don't know thiner in english, I'm indonesianese). Don't forget also check the "kawat" (thin hard wired?) in the memory card slot. If you see the "kawat" is/are bent, you can straight it. May be sometime i will get a picture when I meet the same problem again. And, i will post at my blog. I hope is usefull for you Hayley.
Jul 24, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Casio Exilim ex-z40 won't down load
Try reinstalling your camera drivers. You need to uninstall it first while docking station is removed. Then reinstall your camera software through the cd that comes with it then try plugging it in again either on the same usb slot or a different usb slot. Then try docking the camera again if theirs any interruptions. Usually if you transfer the docking stations usb cord plug to a different usb slot, the transfer goes haywire. Try transferring to a different usb slot...
If all else fails, get a card reader for your cameras memory card, it is way faster...
Feb 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Casio Exilim won't turn on when memory card is inserted
It sound like a bent pin issue. Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck !
Aug 04, 2007 | Casio Exilim EX-Z57 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
