Question about SanDisk Sansa Clip MP3 Player
Need the clip that goes on the back of the play to hold on my clothes
    President:
  • 2,777 Answers
I believe I found the type of case / clip on system you are looking for. I will give you the link at the bottom of my answer here..
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www.amazon.com/gp/product/B001BFLS4U?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001BFLS4U
Thanks
Tim
Posted on Oct 12, 2010
Does the Eclipse Fit Clip Plus have resume play functions?
I have just discovered that if you pause the player and then let it shut off on its own then press pause again later to wake up the unit and again it will pick up where you were. Now, I don't know if it uses any battery life when it's sleeping so will just have to experiment there. But the key here seems to be NOT actually turning it off. Turning it off will reset it to song #1 every single time. Which is really obnoxious.
Feb 01, 2015 | Eclipse Fit Clip Plus 8GB* MP3 Player
I have a Sansa 4GB. It has been a great machine. Lately, however, when I try to turn the volume up or down, there are problems, it does not repsond or the sound fades in and out.
Hi, first you will need to troubleshoot to know exactly what makes it malfunction before you will need to reset the mp3 player.
Pause the Clip before powering off the device and attaching it to the USB adapter. If you turn off the Clip while it is playing a track, it will resume playback when connected to the adapter and prevent it from quickly charging.
Reset the Clip by holding the On/Off switch in the On position for approximately 20 seconds. Release the switch, then attach it to the USB adapter to charge it. This process can help when the Clip does not appear to be working at all.
Reload the Clip's firmware (available on the SanDisk Web site) if your MP3 files play correctly on your computer but do not play correctly on your Clip.
Enter the "Settings" menu on the Clip and select "Format" if you are not able to transfer any files onto the device. Be warned that this process will delete all of the current content on your Clip.
How to Reset a Sansa MP3 Player
With a Sansa MP3 player, you can easily listen to music wherever you are. Like most computer-based devices, Sansa players can sometimes "freeze," which will effectively stop the device from playing any files and from obeying buttons. Luckily, it's a quick and near effort-less challenge to unfreeze it and make it work again.
Instructions
Reset via command
Push the "Power" switch downward into the "Hold" position.
Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
Push the "Power" switch upward all the way to turn it back on.
Reset via switch
Grab a steady hold around the device.
Push the "Power" upward and hold it there until it powers off.
Power the device back on by releasing the power switch and then pushing it upward again.
Force reset via power-cutting
Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
Take out the batteries from the slot and wait until the screen goes black.
Insert the batteries the same way they were mounted and attached the lid again.
Push the power switch upward to turn on the device.
Tips & Warnings
A good idea to stop Sansa devices from freezing is to always make sure that the player's firmware version is up-to-date. Download the firmware updater software from the Sansa website (see link in Resources).
Hope it helped.
Feb 23, 2011 | Audio Players & Recorders
How do I replace the coupler on my Admirl washer? Also, How do I know for sure if it is the coupler?
Greetings,
if it fills with water but will not agitate and will not spin, but it will drain...its most likely the coupling. The front can be removed for ease of replacement /or you can tilt the machine back to wall...UNPLUG....remove wiring to motor and remove two spring clips holding on pump...remove pump and set aside....,,,remove two clips holding motor and pull out motor....one coupling goes on motor, other goe's on transmission...i would find something like a piece of 5/8 pipe to drive coupling onto transmission. just makes it easier...reverse procedure and enjoy washing your clothes
If you wish to remove cabinet...remove screws going into console..these could be hidden under corner trim or behind console on each corner...or in place site front corners....flip up console and remove wirng going to lid switch..it has a disconnect plug...remove two corner spring clips and pull cabinet up and off.....
Jan 23, 2011 | Washing Machines
How do i open the back seat of my pontiac g5 to get into the trunk?
This is easy. Get a friend, you need a little help. grab hold of the bottom seat by slipping your hands in the crease. Lift it up. The seat will lift up towards you. There are some clips on the bottom. of the seat, slide the seat off the clips and take the seat out of the car. Most backs have bolts holding the back in place. Undo the bolts, and lift the seat off the top clips,, and remove from the car. Goes back the way it came out.
Dec 26, 2010 | 2008 Pontiac G5
I can't seem to remove the window handle retaining clip... I can't even find it
on a typical window handle, there is a c-clip that holds the handle on that you can't see, the best way to remove it is with a small rag or cloth, wrap the cloth behind the handle and pull the two ends away from the end you hold when you use the handle and rock back and forth a little bit, it takes a while but you will eventually work the clip out of its seat and the handle will slide off.
Jan 16, 2010 | 1997 Hyundai Accent
Cant get the clips back on that hold back to top on kenmore s 70
Looking at the clip from the side there are two hooks. One goes into slots in the washer back and the other snaps into the cabinet.
Starting with both tabs on the clip facing up, the tab with the longer end hooks into the back. The shorter end lays on top of the holes in the cabinet.
Smacking the clip down seats it in the cabinet. It will only go in one way.
Sep 20, 2009 | Kenmore 22422 Top Load Washer
HOW DO I CHANGE THE BELT? pl-112d
There's a very small c-clip on the top of the mainshaft. Take a icepick or dental pick and while holding a cloth around the area, pick off the clip. Believe if you don't use a cloth you WILL lose the clip. After that removre the rubber pad on the turntable and you'll see a large hole. the belt can be reset in place from this hole. Remove the turn table straight up (after removing the belt from the drive pulley) and lift it off. The rest will become clear. To replace the clip,again, keep a cloth near the area and push it back into the groove with a wide bladed flat screwdriver.There you go!
Aug 13, 2009 | Audio Players & Recorders
E15 water is draining but clothes still sodden,
The problem is your pump or filter is blocked.
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me plz……………………….
Mar 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Replace wire clamp around seal
You need a grip clip plier to handle this clip, enquire at a hardware tool shop, with problem. The clamp is tough, you dont want leaks.
Mar 01, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore 70 series
Mrquest
If it is draining the water then the motor is running. ou most likely have a broken motor coupler between the motor and gearcase.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back with the complete model number from the washer if you need further help.
Thanks, Mike
Apr 02, 2008 | Kenmore 22422 Top Load Washer
SanDisk Sansa Clip MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
