Question about NetGear DG834G Router
My ipod touch connects to wifi OK, but will not connect to the internet. I suspect there is a problem with the router settings, please advise me
Wifi is ststed on my ipoad but not any appliction open which links to internet no skypee and when open skypee its will says check your network settings
Posted on Nov 22, 2010
I cannot connect my ipod touch to my router how do i connect it?
First you'll need to turn on your Wi-Fi.
1. Choose (Settings) then (WiFi) then (turn WiFi on)
2. Set iPod touch to ask if you want to join a new network: Choose (WiFi) and turn (Ask to Join Networks) ON or OFF.
Then you'll need to join a WiFi network (your D-Link for instance)
1. Choose (Settings) then (WiFi) then wait until your D-Link shows up in the list of networks.
2. Select your network and if you have a password for your router make sure you type it. (networks that require a password have a lock icon next to it) then tap (join)
Once you join a WiFi network manually, iPod touch will automatically connect to it whenever the network is in range. If more than one previously used network is in range, iPod touch joins the one last used.
When iPod touch is connected to a WiFi network, the WiFi icon in the status bar at the top of the screen shows the connection strength. The more bars you see, the stronger the connection.
Good Luck
Dec 25, 2010 | D-Link DIR-600 Router
How do i get online with my ipod touch
Open up settings click wifi click turn on wifi if any available routers are nearby it will show up click on the connection you want then open up safari.
Jun 20, 2010 | Apple iPod touch
Wont connect to internet
To connect to the internet using wifi on the iPod touch, just follow the following steps:
Firstly, you should be in a wifi zone(an area where you can access wifi) or if you want to use it at your house with your residential internet connection, just get yourself a wifi router(shouldn’t cost more than $50-60) and configure it with your residential internet Once you are in a wifi zone, on your iPod touch, go to:
Settings > Wifi > Turn your wifi ON > Select a wifi network > Key in the WEP(only if asked for) > Connect
Once you’re done with this, you should get the IP settings and be able to surf the internet with no problem.
Note: At times when you’re too far away from the wireless router or a big thick brick wall is separating you and the wifi router, your iPod might show the network as available and you would also be able to connect to it, but surfing the internet using it would become a problem. If this happens to you, don’t worry, just move closer to the wifi router and it shouldn’t pose any other problems. Happy Surfing!
dont forget to rate me.....
Apr 05, 2010 | Apple iPod touch
I have wifi signal but cant connect
Try going to settings, wifi, then click the name of the router. Type in the password (if needed) and click ok. If this does not work tell me what else u tried.
Sep 07, 2009 | Apple iPod touch
IPod touch doesn't connect to wifi
Go to the settings and check if your wifi network is listed under WIFI.
If not unplug your modem, wait 30 secs, plug it back in and check ipod again after 4 mins. If not, then you wifi router is broken. you can try unplugging that but i doubt it will work.
Aug 09, 2009 | Zyxel P660HW-D1 Router
Will not connect to internet cannot find server
Go into your itouch in settings and wifi.
make sure your wifi switch is on
see if your wireless network is showing and choose it.
enter your wep key and it should connect.
if your ipod is not seeing your network click other
enter the name of your network and the wep key from the bottom of the router and
see if it joins.
good luck
if this helps you please leave a fixya vote
Apr 27, 2009 | Apple iPod touch
Unable to connect to wifi network on ipod 2g touch
You must have your wireless profile's name and passkey.  Try resetting your router, then make sure you create a new profile for your desktop and take note of the details (ie name, WEP/WPA Key)  Should work just fine if you follow the steps.
Feb 14, 2009 | Apple iPod touch
Connecting but still not able to brower the internet
hi
the router is not giving IP. restart the router to solve the issue.
from ipod delete this wifi network by right click and forget network. connect again.
update me
Dec 19, 2017 | Belkin (F5D7230-4) Router (587009)
Ipod touch - wireless connect to my MSI RG54g2 router
Hi and welcome to FixYa,
Initially, to your queries:
  • instruction book - pls click here;
  • passwords - open a browser, the MSI RG54G2 web interface is 192.168.1.254, password is "admin", less the quotes;
  • iPod touch - will auto detect your MSI
  • setting on my router - if allows your computer(s) to access the Internet, no further settings required;
  • iPod can connect to the internet - if no WEP or WPA is set on the MSI router.
This is of course assuming that the MSI RG54G2 is allowing your computers to access the Internet lready and will be shared to the iPod Touch.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 25, 2008 | MSI RG54G2 Router (MS-6848-002)
Unable to connect Ipod Touch to Internet via Wifi
im no sure wa kind of router i have, bu iam sure that i have the right password and i comes up with the networks i could connec to and i try connecting to my home 1 and it comes up "unalbe to connect to this network" my sis or my mum can connect either we all have ipod tocuhes and its getingfustrating. can any one help?
Nov 16, 2008 | Belkin (F5D7230-4) Router (587009)
NetGear DG834G Router Logo
78 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
