Question about Bose Wave Radio
Remote control problem
This is our second remote control the first stopped working about three years ago. It almost seems like a battery issue although we have changed it and it seems to do the same thing. We need to hold it very close to the system and try to turn it on several times sometimes it works and sometimes it does not. When we do get it to work then we can get it to turn off. Is this a remote issue or system issue. Thanks for any help or suggestions.
  • Anonymous Jun 09, 2008
    changed the battery on the wave radio remote....nothing....what now?
    please help
  • nhkenny Mar 25, 2009
    I have 2 wave radios, both have remote problems. One radio came w/2 remotes, one works o.k. most of the time the other doesn't work at all. The other radio's remote doesn't work at all now. tried new batteries, no luck. Is this a common problem with these things? Great radio when it works.
Replacement remotes for my AWR1 were $10 from Bose. Order online; receive by mail. I just bought two.
Posted on Jun 12, 2008
My control lights up on sat when i push power. It then does not respond in any way.Batteries are all new,and tested..Years ago I had a control that I would open,remove the pad,andclean the pad...
Hello, Matt with DISH Network here. If the remote is still not working, open the door on the front of the receiver and press the "System Info" button one time. When system info is on your screen, on the remote press the "SAT" button one time, and then press the "record" button three times. Try pressing select to see if it is now working. You can also try to hard reset your receiver. To perform a hard reset, you unplug the receiver from its power outlet, wait 15 seconds, then plug it back in. Try reprogramming the remote again with the first part of these instructions. If the remote is still not working, it may be faulty. If this has not been resolved please feel free to email me at matthew.gonzales@dishnetwork.com. Hope this helps!
Dec 26, 2010 | DISH Network 135899 Remote Control
2005 Colorado drivers side window and remote locking system
Just figured it out and replicated it 3 times..
any type of power/voltage change seems to trigger this issue
The most common symptom is power locks fail and only the driver window quits, however that is on the extended cab.
Steps to fix and it works every time.
take door panel off driver's door
Disconnect the wiring attached to window and power lock control unit
disconnect battery cables
connect the negative to the positive cable(((NO BATTERY CONNECTED)))
This will act to short residual voltage in the system
5 minutes later
place the key in the ignition and turn to the run position
connect the wiring to the window/lock controller
connect the negative cable to the battery
then the positive
open drivers side door
turn key to the off position((do not remove yet)) you should get a series of dings through speakers telling you the key is still in the ignition
once it begins dinging pull the key out and you should hear the door lock solenoids trigger and the windows should work.
Three years and a very unhappy girlfriend who owns the truck. but she's happy now.
Feb 13, 2010 | 2005 Chevrolet Colorado
I have an old hitachi 55ex1k projection tv that up until now hasworked great just three days ago it seemed asif the tv had a power surge afew times now it has progressed to working for three to five...
try this site
GenuineCopies Remote Control hyundai hlt3270 - Universal Remote ...
GenuineCopies Remote Control hyundai hlt3270 No Setup - Just put your batteries in and off you go. Our remote controls are generic replacements 100% ...
en.kioskea.net/.../52219306-genuinecopies-remote-control-hyundai-hlt3270 -
Nov 24, 2009 | Televison & Video
Only 1 remote will work at a time
One of your remotes has reverted to an earlier technology and they will no longer work with each other. You need to purchase a new remote making sure you get the same model number. Then you will find you can program 2 that will work with each other and 1 that will not. Remove the battery from the bad remote and toss it so that it doesn't cause problems down the road.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Sep 19, 2006 | Philips 28PW6506 28" TV
Bose Wave Radio Logo
893 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
