Question about Panasonic Car Audio & Video
Hi i am trying to fit a panasonic model number cq-c1110an to my 1995 rover metro but the power supply plug is different and the connecting pins do not fit colour coordinated, can you tell me the correct wiring code ie which is permanent live, ignition live, earth, and what the other wire on the rover plugs represent. the colours i have on the rover wiring are green purple black red with black lines through but i am unsure which to connect which too as the plug on the rear of the stereo consists of 1 red 1 black 1 yellow and 2 blue and white together the yellow is marked battery 15a and the red is marked acc
    Habit-Forming:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 36 Answers
I have to say it, so let's get it out of the way; there are many professionals in your area who are capable of doing this for you. Whether it be Car Stuff or a Land Rover dealership, you can expect to have everything put just the way you want. But I have solved this problem myself once...
I have run into this problem on my Nissan Maxima. My solution was a bit extreme and involved quite a bit of butchery. You may decide to do something else. What I did was cut the connector off(to the original stereo) of the cart and spliced the power wires together. Then I turned on the unit and put in my favorite cd, adjusted balance to the front-left and touched wires together to figure out which was the proper speaker wire. Then did the same for front-right, rear-left, and rear-right. After figuring out the proper way to wire it in, I went back and installed ****-end connectors(wire nuts will work, but take up more space) and re-wrapped with electrical tape, making sure there were no wires or metal to ground out. If you do decide to cut the connector from the vehicle, leave enough wire on the connector so it can be reinstalled at a later date, 2-4 inches of room to work with(just in case you need to reinstall original stereo unit).
Think long and hard about if you decide to make this work. It is dangerous to modify a vehicles electrical system due to a RISK OF FIRE . Let me say it again--there are professional automotive audio people in your area who can do this. Check with Best-Buy.
Posted on Oct 12, 2010
THE PANASONIC CQ-VD6503U TURN OFF BY SELF AFTER 10 MINUTES
hi Alex,
It can be loose connection.please check all plugs and jacks.
specially power + wire and fuse etc.....
then if the problem is same internal loose connection maybe a problem.you must do the electronic repair for that.
regards,
nuwan.
Jan 24, 2014 | Panasonic CQ-VD6503U Car DVD Player
Panasonic car head unit CQ-VW120W, my aftermarket adaptor is missing 3 wires so I'm looking for pinout info. I know what all the colors are. I just need to know which pin numbers do what.
All parts and service manuals can be obtained by calling the Panasonic National Parts Center directly at 1-800-332-5368 9am-8pm EST during weekdays.
Sep 21, 2013 | Computers & Internet
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
Just bought rover metro 1.1 brakes not good do i
Take the car to quickfit, they will do a free brake check and,if required,fit front pads,rear shoes.Metro not good at breaking anyway,stops wheels from locking too quick....also as your car is fairly old change the discs as well.will make all the difference.
Jun 03, 2010 | 1993 Land Rover Defender
I want to install in my car a panasonic car stereo AM/FM/CD player CQ-EN9680TA, i dont know the wiring code of the terminal (power and speakers connections), can you help me pls? thank you
Hello marlomeneses,
Wiring color codes are different for different makes and models. Go here and select your vehicle for the color code: www.modifiedlife.com
The best way is to purchase a vehicle specific wiring harness that plugs directly into your car wiring. Splice the wires from the harness that came with your new Panasonic to the vehicle specific harness and plug them in.
Here's an example of such a harness made by Scosche. This one fits 2002 and newer Chrysler/Jeep vehicles. There's a harness for most all vehicles. Local car audio shops, Best Buy, and even WalMart sell such harnesses.
http://www.sonicelectronix.com/item_1669_Scosche+CR02B+-+CR02.html
Hope this helps.
Oct 06, 2009 | Panasonic Car Audio & Video
Panasonic cq-c1323nw reset button
hi there type your model number into this link and you can download the user manuall, i've tried it for your model no and it works.
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
May 02, 2008 | Panasonic Car radio CD CQ-C1110GN CD...
1- Panasonic 7'' monitor model # CQ-VA707WEUC 2- Panasonic brain model #YEPOFX3799 I NEET THE id CODE
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Panasonic BT-LH900
My panasonic cq-df402u
you have to purchase an adapter to fit an aftermarket stereo into a car. you can buy one at wal mart and the come with instructions just buy the one for your car. make and model.
Dec 12, 2007 | Panasonic CQ-DF402U CD Player
Car Audio & Video Logo
326 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
