Question about Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Slipping in high speed - Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
  • 7,733 Answers
It seems like the "CHUK BEARING" is burn. Go here and look around -.link.
Posted on Oct 14, 2010
Clutch slips at higher speeds
replace the clutch master cylinder or cable
indicates that the clutch is not fully engaging , is building up heat from minute slipping and fading out at high speed
Mar 28, 2018 | Cars & Trucks
2007 Kia Sportage clutch slips in high gear
If engine revs increase but road speed does not increase, your clutch is coming to the end of its life and needs to be replaced
Jun 06, 2014 | 2007 Kia Sportage 2.0
Code p1726
it dont lie, it is slipping.
the TCM sees the input speed and output speeds, (trans)
and knows the slip rate. (TC's do slip naturally) and then if it slips too much. it throws the DTC,
must folks do the full flush service. and pray it fix it. (filter and all new ATF fluid)
is the ATF LEVEL too low or too high?, (the test is in the operators guide. not checked at all like the engine, RTM first)
some newer cars have no A./T dip stick to do this, and needs under car, check.
just take it in for service. and check the trans.
ATF = automatic transmission Fluid, RTM means read the manual.
Mar 30, 2014 | 2004 Jeep Grand Cherokee
NEW RACK & PUMP: Steering is still hard at slow speeds. Why?
If the belt is slipping it would do even more so at higher rpms. Plus it would be harder to tell if it is slipping at high speeds due to the fact that just about all rack and pinion systems steer easier at high speeds.
My best guess would be air in either the lines or pump. Driving will not remove the air as it is a sealed system.
Jul 08, 2013 | 2005 Ford Freestar
600 shadow transmission slipping. What is the cause
If the transmission is slipping then you will need to replace your clutch plates. you don't say how old the bike is, so this may not be the case. But you should check the adjustment of the clutch lever anyway.
Apr 10, 2013 | Honda Motorcycles
My drill slips under high torque
check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Nov 04, 2012 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
2002 Chevy silverado, at speeds of 60+ mph, it feels like the transmission slips or it sputters(hesitates), but only at high speeds
Are you certain that it is the transmission and not the engine misfiring? I would recommend scanning your onboard computer network to BEGIN proper diagnosis.
May 20, 2012 | 2002 Chevrolet Silverado 1500
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
My 2005 Kawasaki Vulcan 750 is struggling in fifth gear, and intermittently tachs high at speeds over 55mph.
If the bike is reving high in top gear but you are not gaining speed or very little speed your clutch is slipping. This is a sign the clutch needs replaced.
Feb 12, 2010 | 2005 kawasaki VN 750 Vulcan
Milwaukee 1670 1 Drill 1/2 900 Hole Hawg Logo
213 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
