Question about GE Spacemaker JVM1740 Microwave Oven
Some number on touch pad do not work. Any suggestions or part number replacement?
    Sergeant:
  • 270 Answers
Go here to get parts you need.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5212347
Good luck and don't forget to vote
Posted on Oct 12, 2010
Microwave was beeping a single beep once in awhile now nothing happens but the clock still works
A lot of the time when that happens the touch pad is bad and may have a colappsed air pocket on a pad. ( it makes the unit think you are pushing a pad ) The only way to fix it is to replace it (the touch panel) . Did you see any numbers coming up in the display. Like if the 3 pad was bad and making it beep it may have been showing a 3 in the display,. Always possible it could be a bad main board. But most commonly I have found it to be the touch panel. Try to unplug it and then plug it back in and try to set the clock. when you do, try each number pad and see if they all work. See if any feel different.
Oct 17, 2017 | In Microwave Ovens
Why are GE Profile JT930 touch pad numbers not working?
Seems problem with the touch pad. Try replacing the same.
Aug 16, 2014 | GE Appliances 30" Trivection Built-in...
THE KEY PAD QUICK WORKING. I HAVE REPLACED THE CONTROL BOARD BUT THEY STILL DO NOT WORK.
Hello, Thank You for using FixYa. I will be helping you today.If the buttons are not working replace the touch membrane. I would list the part number but you didnt give full model number.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Frigidaire PLMB209DC Microwave Oven
My touch panel on the door does not work. any
When these go out the usually have to be replaced, there are no replaceable parts for them. Usually you have a stuck button and this is from pushing it too hard, or cleaning fluid gets into the pad and the problem is the whole touch pad gets ruined and has to be replaced. Unless your familair with small appliance repair I would have a tech look at this.
Mar 23, 2011 | Electrolux EI30BM55H Microwave Oven
Some of the touch pad numbers on my microwave are not working
That is usually a faulty touch pad.
Contact an appliance engineer to get a price for replacement and ebay for the spares to see if it is a fair price.
Hope that helps.
Feb 25, 2011 | LG LMV1680 Microwave Oven
On the touch pad numbers 3, 6, 7 and 0 dont work
sounds like the touch pad control has failed ... there is a touch pad on this unit and also a control board located behind units touch pad... you can gain access to this by unplugging unit and removing console that houses touch pad /clock assembly ... once removed the only test there really is to do would be with power off remove ribbon cable to touch pad and make sure clear of any dust /debri and reconnect there are 2 small holes in ribbon cable that are used when reconnected fir into small slots and firmly connect... if that doesnt fix i would recommend a new touch pad... not sure what area your located... there is a distributor for sharp in dallas ,texas called
global micro parts... reputable company that if you give them your model number they can assist you with the part.... good luck to you
Jan 27, 2011 | Sharp R305KS Microwave Oven
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
Microwave Buttons Not Working
all the buttons are connected to 1 control touch pad board.so only two faulty buttons cannot be replaced.whole touch pad of buttons pannel has to be replaced.the cost of the whole pannel will be near to $45 plus service tax.
but as you mentioned its just six months old.contact the dealer as it must be under warranty.if the problem of buttons is considered under warranty you will get the replacement unit or may be the company will get the touch pad replaced for free.
thank you for using fixya.
Apr 03, 2009 | Microwave Ovens
GE Spacemaker JVM1740 Microwave Oven Logo
120 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
