Question about Kohler Home
My new K-4632 AA toilet flushes fine and refills the bowl. The tank equipment works as it should. Problem is, the bowl completely empties in about 5 minutes and stays empty until the next flush. The water isn't leaking on or through the floor so it is clearly going down the drain. There must be a connection from the bowl trap directly to the drain. Older toilets didn't have that, but this one looks like a little passageway is cast into the toilet. I have another of these toilets and it works perfectly.
  • 10,865 Answers
Hello. Your toilet is leaking through the flush valve. This is a serious issue as it will use a huge amount of water every day. Check to be sure there is not an obstruction in the tank and if you can not find one, call the plumber. J.
Posted on Oct 13, 2010
Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
WASH YOUR HANDS THOROUGHLY afterwards.
Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
It takes a long time to fill the tank
There could be partial blockage of the water supply line causing a slow fill.
Feb 20, 2014 | Kohler Cimarron Comfort Height elongated...
When flushing, only a small amount of water leaves the tank, and the bowl just empties. The chain has a little slack to close, however, it does not hesitate at all. When flushing, the chain lifts the...
Try holding the handle down until the tank empties completely. If the tank leaks into the bowl during or after refill, the flapper is defective and not sealing correctly.
Jun 21, 2017 | Kohler Memoirs toilet tank with Stately...
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
Just installed the cadet 3 and here is what is happening. First let me say that the toilet it replaced was working good. The water filled very slow and the bowl would not fill much. I messed with the...
The amount of water in any toilet bowl is determined by its construction and no tank adjustment will ever change that. American Standard has a history of having small water surface areas in their low or ultra low flush toilets. Take a large container of water and pour directly into the bowl. If the ending level remains the same, then that is the manufactured level for your toilet.
Not all tanks completely discharge all of the water when flushed. Measure 1.5 gallons of water into a container. Turn off your water supply to the toilet then flush normally. Replace the water in the tank with your premeasured amount and observe this new water level. You might be surprised to find it is at the same level it always is. Since water weighs more than 8 pounds per gallon, one concept used in todays toilets is to have more than 1.5 gallons of water in the tank and use the extra weight push the water past the flapper at a faster rate while designing the flapper to drop after only 1.5 gallons have passed through.
Sep 29, 2010 | American Standard Cadet 3 Right Height...
Installed new tank. Flushed fine 2 times, then
The flapper isn't staying open long enought, try holding down the handel for a few seconds each time u flush.
Mar 10, 2010 | Home
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
Tank not holding fill level...
Most likely, you do not have a good seal on the flapper valve at the bottom of the tank. To confirm, try this:
Turn off water and flush toilet. Then lift up the flapper valve and put a light coating of vaseline on the mating surface where it contacts the toilet tank when closed.
Turn water back on and see if it continues misbehaving. If that fixes it, it was a bad seal. Usually that is all it takes.
Dec 15, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
When you flush, the bowl refills and then suddenly empties 90% of the refilled water. Why? This is a toto toilet and this happens almost all the time now.
it sounds like it is not flushing completely at first and then releases and the suction is pulling water out of the bowl. Could be a venting issue or a clog issue that is hindering the proper flushing of the toilet.
Nov 23, 2009 | Toto Home
Home Logo
509 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
