Question about Siemens Electrical Supplies
I have a Bulldog Pushbutton breaker box and one of my breakers is bad. The part number on it is P5140-2. It is a quad breaker 15/40/40/15. I cannot find a replacememt and I was wondering if I could replace it with a 20/40/40/20 (ITE P2040-2)?
  • lwkish Oct 12, 2010
    Thanks, I will check the gauge of the wire as soon as I get home!
    Thanks! I will check the gauge of the wire as soon as I get home.
  • Siemens Master
  • 43,501 Answers
You cane replace that with the 20/40/40/20 as long as the wire size on the two 20 amp poles are at least 12 gauge wire. It is a very good possibility that the wire is #12 wire, but you will have to verify that for sure before installing that breaker.
All of those breakers are getting more difficult to find and I'm sure that the quad is even more difficult.
Hopefully you have the 12 wire and then it will be no problem and you will be in good shape.
heatman101
Posted on Oct 12, 2010
Does any one know what I can substitute in place of a Milbank breaker.
go to a good electrical wholesaler with one as a sample.
Breakers Compatible with Milbank Box? - DoItYourself.com Community ...
www.doityourself.com > ... > Electrical - AC & DC
Oct 8, 2004 - 3 posts - ‎2 authors
I need to add a breaker to my Milbank breaker box (circa 1982). Are these available only through electrical stores? Can't find 'em at Home ...
Milbank - The Home Depot
www.homedepot.com/b/Milbank/N-5yc1vZ6jm Shop our selection of Milbank, in the Department at The Home Depot. ... Breaker Boxes (5) · Metering & Temporary Power (54). More departments... 59. 0 ...... Milbank 125 Amp 5 Terminal Ringless Overhead Quad Ground Meter Socket.
Milbank - Breaker Boxes - Power Distribution - The Home Depot
www.homedepot.com > Electrical > Power Distribution > Breaker Boxes Shop our selection of Milbank, Breaker Boxes in the Electrical Department at The Home Depot
Milbank breaker Google Search
Mar 15, 2017 | Electrical Supplies
Where can i get rockworth concrete breaker brushes
model numbers are 3 different 0 611 255 539
0 611 255 739
3 611 B55 539
But brushes 1 617 000 525 are for all models the same bosch number.
Online to buy ( 1 suggestion )
BOSCH CARBON BRUSHES GBS AND GSB PART 1 617 000 525 GBH 2 22E GBH 2 26DFR...
Jun 14, 2014 | Bosch SDS-plus BULLDOG Xtreme Rotary...
We have a westinghouse box and it has a 200 amp main breaker, but we cannot find a 200 amp breaker anywhere. Do you have any idea where we can locate one??
You should get the exact breaker number to be safe. Westinghouse is not Eaton. Here is one example.
http://www.acehardwaresuperstore.com/westinghouse-replacement-main-circuit-breaker-p-21528.html
There are many places online. 200A breakers rarely fail, unless loose connections on lugs (AL WIRE) cause overheating.
Aug 14, 2010 | Bryant Westinghouse Bqc Quad Circuit...
I have three bulldog pushmatic circuit breakers that will not push back in? Are they gone or can they be reset.
Either they are bad, or are "tripping" If they won't push in when removed, then they are bad. Not unusual. You can still buy them. Look online or Box stores
Jun 17, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
I need to buy a 20/20 Amp Bulldog breaker for a dryer and any installation tipes
Most electrical dryers are 220 volt. They usually require at least a two pole 30 amp circuit with #10 wire. The breakers you need can be found at most hardware and buidling type stores, Ace , Home depot, Lowes.
Yes they would have the 20/20 breaker also.
Please Vote !!
Apr 24, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
Bulldog breaker dead. Reset button depressed, but would not reset to on position, button remained depressed inward
These breakers do fail. Sometimes you can get them to reset by repeatedly pushing the breaker, but you would probably only get lucky once. These breakers are still available as replacements, and are at big box stores. These breakers bolt in, however. You should only attempt to replace the breaker if you have a main breaker that you can open to remove voltage from the rest of the panel. Even in a 240V residential panel there is a serious arc fault flash potential. If you have any doubts about replacing it yourself, consult someone with experience.
Mar 25, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
Breaker wont push back in
it is still detecting an overload in the circuit. Take the black wire off the breaker and see if it will reset. If so then you will have to trace the wires down to find the short circuit. If it doesn't reset then the breaker is bad
Jan 25, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
My Mom (86) has a bulldog panel with an intermittent 15 amp breaker. How do I remove it?? I was afraid of putting a screwdriver in between it and the main verticle strip (buss bar) and prying it out after...
The pushmatics get sticky more than trip when they shouldn't. Are you sure your Mom isn't just overloading that circuit? If so, changing the breaker or even changing the panel won't help.
Some Bulldog panels have the main breaker separte to the side of the branch circuit breakers - under the meter. I think some of them are designed so that you can de-energize the bus by turning of two of the top breakers, but I'm not sure.
You definitely shouldn't do this live. Have a meter to make sure it's not live when you do it. It would be very easy for your screwdriver to touch the bus bar and the metal frame at the same time.
But, again, maybe the problem is too many things plugged in.
Dec 23, 2009 | Bulldog Electrical Supplies
Pushmatic 15amp breaker was buzzing. I turned it off and then pushed it to on again and the bussing was gone. Is the breaker going
Not necessarily, if the buzzing stopped then its probably ok. When a circuit goes bad, either they fail to trip open, or will not reset to the on position
Aug 02, 2009 | Bulldog Pushmatic 31115 P115 15 Amp...
Electrical Supplies Logo
535 people viewed this question
Top Siemens Electrical Supplies Experts
Craig Butler
Craig Butler
john h
Steve
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
