Question about Saniflo 002/005/007 Saniplus Toilet with Macerator Series Pump in White Elo
How do you get more water to stay in the toilet once the toilet has been flushed
  • 10,865 Answers
Hello. Increase the amount of water that stays in the tank and you will automatically increase the amount of water in the bowl. Joe.
4 thumbs up please.
Posted on Oct 12, 2010
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
I have a saniflo system I just installed....what is the best type of toilet paper to use? And should I flush the toilet more than once to insure it stays clean?
many consumers prefer Charmin ultra soft .not necessary unless it doesn't go down the first time . Just wasting water .
Oct 04, 2015 | Saniflo Home
I have a Kohler dual flush cartridge toilet and on small flush there isnt enough water being released to wash any paper away. We have two toilets like this and one flushes much more than the other. Can the...
not really as the flush time is set by the manufacturer in the design
what can be adjusted is the water level in the cistern
the more water , the longer the flush before the reset ( shut off)action is activated adjust that by the float screw ot water level adjust screw on the inlet stem
Feb 27, 2015 | Kohler Home
I have K3397 Kohler toilet. Water is running little by little. How to stop it?
open were the water system is flush once watch the water rise localize the floaty tat rises with the water once u localize the floaty their will be adjuster were the floaty is then just lower the floaty adjuster down 2 half inches down once ur dun flush then the problem shud be solved.
Aug 18, 2010 | Kohler K-3360-G Revival One-Piece Toilet...
When flushing toilet, water spins in bowl but does not flush away. Have used plunger to no avail. However, if I pour a 3 gal bucket of water into the toilet bowl, it flushes just fine and the water level...
Alot of times this problem occurs when there is not enough water in the tank behind the seat and bowl. Lift off the tank lid and see how much water is it, It should be near full.If it is not your problem is not enough water.
Feb 21, 2010 | American Standard 2071.016 Heritage One...
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
Have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Dec 15, 2008 | American Standard Home
Saniflo 002/005/007 Saniplus Toilet with Macerator Series Pump in White Elo Logo
113 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
