Function address 0x4f5d9f78 caused a protection fault. (exception code 0xc0000005)
  • gkappe Oct 13, 2010
    HP officeJet pro L7580
  • 6,993 Answers
What's the name and model of the device with this error code?
I look forward to your reply
Bye for now.
Posted on Oct 12, 2010
  • Walesarumi
    Walesarumi Oct 13, 2010
    to fix the problem, you need to reset the printer. Follow the procedures below to successfully reset your printer:
    1. Without turning off the product, disconnect the USB cable from the rear of the product.
    2. Remove the cartridges from the printer.
    3. Wait for the "Insert Cartridge" message to display on the control panel.
    4. Disconnect the power cord from the back of the product.
    5. Wait 60 seconds.
    6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
    7. Reinsert the cartridges, and then close any open doors on the product.
    8. If you receive a prompt to print a calibration page, do so.
    9. Reconnect the USB cable to the rear of the product, and then try printing again.
    Take care.
The application failed to initialize properly (0xc0000005). click on ok to terminate the application
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
You can read more about DEP at:
http://www.updatexp.com/data-execution-prevention.html
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers and then "Google" to see if their are any other folks reporting this issue. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the tag, an access violation may occur.
Mar 03, 2011 | Computers & Internet
Error running th game "Casino Inc." in Windows XP SP2
What Causes Windows Error 0xC0000005
A quick scan of the online technical forums and blogs reveal folks asking for help with this windows error. Your question may be the same as this typical request:
I'm running Windows XP and when I click to start one of my software programs I get this error:
The error 0xC0000005 is generated by an ******* "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
/NOEXECUTE
Oct 30, 2017 | Konami Casino Inc. for Windows
Fatal application error
pplication adeona. oddysseyCore has performed an illegal operation and will be shut down. if the problem persists , contact the program vendor. program: adeona.odysseycore exception: 0xC0000005 address: OO1FOAEO
Aug 26, 2009 | Nextar X3 GPS Receiver
Cant change printing preferences.
please follow the instructions given in the following document. Click here to visit the instruction page.
May 21, 2009 | HP Officejet Pro L7680 All-In-One Printer
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
Jan 25, 2009 | Acer Aspire 3680 Laptop
HP Laserjet 2015dn will not print
You didn't say what type of printer connection you have (Parallel Port, USB, etc) and this may not help any but I do know that HP Printers are VERY finicky about not pluging in your USB cable until told to do so.
Also, did you uninstall the printer software prior to doing the reinstallation? That can sometimes make a huge difference also.
Oct 27, 2008 | HP LaserJet P2015dn Printer
Application error - the application failed to initialize properly (0xc0000005) when launch Import Media (HandyCam/Dics) application
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
/NOEXECUTE
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Oct 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Intellinav.exe application error
/NOEXECUTE
CAUSE:
Aug 30, 2008 | Nextar Q3 GPS Receiver
Printer problem
Remove your printer from the available printers by deleting it. Shut down. Restart and reinstall it. Make sure your cables are connected at the time the manufacturer tells you to.
Dec 21, 2007 | Lexmark X4270 All-In-One InkJet Printer
971 people viewed this question
k24674
jasbo
jasbo
