Question about Cameras
When I place my infolithium battery into my Sony Cybershot camera, it doesn't work. It works for about 5 seconds, and then the words: infolithium battery only flash and the screen goes black and the camera shuts off. this has never happened before.
  • steerpike022 Jun 17, 2008
    I've had mine fixed once and it just developed the same problem again. I gave in and purchased a DSLR, though I would like to have this one working again as a backup. Is there anything I can do other than sending it off to the repair facility again?
  • 10,594 Answers
Camera doesn't get Info Signal from battery thats why gives such message. One solution is to deattache battery for couple of hours and try again.
2nd is that camera has hardware problem and requires qualified technician to repair it though its not big repair.
Posted on Jun 01, 2008
Use infolithium battery pack
I believe Shahid is correct... it's probably the pins.. try this... first make sure all switches are off during the entire process (viewfinder pushed in and keeping the LCD closed, try cleaning the pins on the back of the camera with a Q-Tip and Isopropyl alcohol (91% if possible)... leave it a bit damp and push the battery into place several times to clean it's contacts too.. then let everything dry, reconnect the battery and turn it on. The problem will hopefully be all gone.
Apr 29, 2012 | Sony Video Cameras
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
My Sony camcorder often stops and a writing appears: "Use the infolithium battery pack" It happens either when I am recording or I am watching the tape and can happen any time, after five minutes, ten...
It sounds like you are using an aftermarket (non-sony) battery pack. The camcorder you are using probably requires the Genuine Sony 'Infolithium' Battery pack (usually in the box of the camera). If you are getting this message with the proper battery installed, i would contact SONY
Jun 17, 2010 | Sony HVR-A1E HDV Digital Camcorder
''for use with compatible battery only''
This appears to be a common fault. You can look up similar problems in fixya with the words "Sony" and "for use with compatible battery only". It would appear to be a logic fault in the battery system somewhere. Here's a couple of solutions with merit that appear elsewhere......
Solution 1)
I took out the battery from the camera; then I made a short-circuit with a small cable between all the three electrical contacts in the bottom of the battery. Then I put the battery into the camera; the camera didn´t turn on. I took the battery out again from the camera and placed it in the charger supplied, in a few minutes the light was off. I placed the battery in the camera, and ... I´m working well with it! (5 people thought this was helpful)
Solution 2) please remove the battery while pressing and holding the power button for 1 min. plase make sure that the battery supplied for yer camera is an NPBG1 original sony battery.
(12 people thought this was helpful)
A final health and safety word - take care when shorting out batteries - they can still give a shock. If you work from the assumption that your battery is currently unusable, then these solutions might work...... or you'll end up with a shorted useless battery (i.e. not really any worse off than now). If you find a better workaround - please post it.
Feb 26, 2010 | Sony Cameras
What does "for inoLithium battery only" mean?
Is it a Sony battery. I had a similar problem on a similar Sony that I fried using an aftermarket battery or at least that is what Sony said caused it. Especially if it is an info battery.
Jun 28, 2009 | Sony Cyber-Shot DSC-P50 Digital Camera
When I place my sony cybershot's charged infolithium battery back in my camera, it works for about 5 seconds, then the screen goes black, and the words "infolithium battery only flash", along...
Camera is not getting Info Signal from battery so it gives error.
One solution is to deattache the battery for couple of hours and try again.
2nd is that camera has hardware problem though its not big and requires qualified technician.
Jun 01, 2008 | Cameras
The new battery may not be an original Sony infolithium type which has internal and interactive circuits. These infolithium types constantly informs you about the battery condition.The only way is to try another battery. Sivaram.V
Mar 19, 2007 | Sony Mavica MVC-FD88 Digital Camera
S75: which battery???
Please note that the webpage has been updated to reflect the proper battery to be used for the Sony Cyber-shot DSC-S75. Links work properly, now.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Cameras Logo
178 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
