Question about Kenmore 45981 Washer
I ran the CLEAN WASHER cycle and it's spilling out bubbles and water It came up with an F-21 code on the panel, and so I tried to stop it. I would not stop and is now sitting with the door locked.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
First I believe for the clean tub cycle you only use Bleach, but, F20 error code is indicating that no water is detected entering the machine. Make sure your water lines are clear, with filter in place, check and make sure the water is flowing easily through the water hoses. You may have an issue with a pressure switch too. You could try to unplug and reset if it doesn;t clear after 15 minutes or so. Hopefully you can find out, if not you may need repair tech, these newer Machines are all circuits, Thanks for your time..
Posted on Oct 12, 2010
Error code e21 on frigidaire affinity washer cleaned pumped and ran a rinse cycle it did fine put clothes in to wash it ran for 10 min. then stopped.
Hello Deena,
Error Code e21
means the water is not pumping out fast enough.The most likely reason is because the washer drain filter is clogged.
Here is a solution:
  1. Pull the machine out from the wall.
  2. Then take the panel out in the rear. Once the panel is off you will see the drain pump.
  3. Disconnect the drain Tube between the Tub and the Pump.
  4. Look inside the pipe you will find the Drain Filter.
  5. Clean the filter out ( you will be surprised of "things" found in the filter) then put the machine back together
  6. Try a full cycle.
That should end your problem.
Best of Luck!
JP
Jun 19, 2015 | Frigidaire Washing Machines
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
During the cycle, it has stopped and the screen is flashing F- 21, what does that mean? The door is locked and when I do get the door open, water spills out. What do I do?
The drain cycle only runs for 8 minutes. F-21 is a blocked drain tube. Open the panel in the front bottom and locate the drain tube (front right) Disconnect it and you will find a little collection area in the tube as it first comes out of the washers tub. Clean it out and try resetting it to drain then all should be fine. I always find coins and other stuff like tissues blocking the flow.
Jan 20, 2011 | Kenmore HE2 Plus Front Load Washer
CODE F-21 NOT SPINNING THE WATER OUT when it comes to the rinse cycle . IT MAKES A CLICK SOUND AND STOPS . THEN IT SHOWS CODE F-21
The machine is not spinning the water out because there's a problem with the drain system as the error code indicates. Either the drain hose is clogged or kinked, the pump filter is blocked, the pump impeller is blocked or damaged or the pump itself is not working at all. The click sound may due to a blocked pump impeller.
Disconnect power and the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter from the pump housing by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 31, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
Ran Cleaning Cycle, lights blinking w/ F- 21min alternating
f-21 is a blocked drain pump.remove the bottom panel,if you have a shop vac get all the water out,you'll see the pump and in the middle there's a piece that you can turn and pull out,first put towels under and around the pump to catch any water that leaks out,turn the part slowly and with your shop vac catch the water with the vac,take your time and open it little by little catching the water with the vac,when you get all the water out twist the middle part out and clean the catch and feel around in the boot and the pump and make sure you have it cleaned out.stick the middle piece back in and start the washer or you can fill it with a gallon of water and put it into a drain cycle and make sure it drains,if it doesn't you cooked the pump and have to replace it,let me know what you find and next time send the model number.
Jul 25, 2010 | Kenmore HE2 Plus Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer won't drain
Remove the bottom panel under the door to access the drain pump. Make sure the washer is unplugged before servicing the pump. The pump will be located under the wash tub in the front of the washer. There should be a small access cover that can be unscrewed to access the inside of the pump. If not, remove the inlet hose to access the pump impeller. HINT: Pull the drain hose from the standpipe and use a shop vac to pull a vacuum on the drain line. This will pull any remaining water out of the drain lines and wash tub. This will minimize the amount of water that spills out of the drain pump when you remove the access cover.
It does not take much to damage this small drain pumps. If you clean the pump thoroughly and it still exhibits drain problems, the manufacturer recommends replacing the pump.
If you require additional assistance, let me know before you rate the solution. I hope this helps you.
Jan 18, 2009 | Kenmore HE2 Plus Front Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 45981 Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
