Question about Neff K5624X0 1GB Refrigerator
My Neff K5624 Fridge has developed a nasty smell. I've stripped is down washed all of the inside, trays and baskets in a bicarbonate of soda solution, cleaned the drainage channel and hole at the back, but still the niff persists. Is there some way of removing the "evaporator tray" to give it a good clean? Or can you suggest some other possible sources and ways to erradicate them?
4 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: I have a 1996 Neff
Flexible PVC equipment wire or strimmer cord works.
Or something like a turkey baster- with plasticine to seal usually does the trick.
When clear, spray with a household cleaner to prevent mould growth.
Hope this provides a solution for you.
Posted on Jul 01, 2008
  • 1462 Answers
SOURCE: I have a Neff fridge
push something flexible down drain or put a small tube into drain hole and blow
Posted on Jul 02, 2008
  • 414 Answers
SOURCE: Neff built-in K4316 -can I get replacement door
Use the link to see which part you requirehttp://www.neff-eshop.com/eshop/neff/gb/prodp.htm?prod=K4316X1/01
page. You can order part online here if you are in the UK if you are not then google NEFF and you should be able to find your countries customer service/spares dept.Hope this helps.
Posted on Oct 04, 2011
Tips for cleaning & remove smell of rotting food fridge accadently tuned off.
  • Place a saucer of bicarbonate of soda inside to absorb odor
  • Use a small bottle brush, chopstick, or similar "tool" to ream the defrost drain and remove residue
  • After completing the above, remove the flimsy plastic evaporation pan underneath, dump it and carefully clean it using liquid detergent and water
Feb 06, 2018 | Refrigerators
Tip
Bad odor in refrigerators...
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
  1. Keep an open box of baking soda inside the fridge it will absorb the foul smell.
  2. Place newspaper made into balls all over your fridge and freezer so that it is completely covered.Spray the newspaper with water until it is completely wet.
  3. Allow the fridge to run as normal for five days. During this time, the combination of evaporating water and paper will soak up the nasty smell. It should be noted that you will have to turn your freezer to the lowest setting to avoid getting frozen.
  4. Buy some freshly ground coffee.Dump 1 to 2 cups of the coffee grounds on a large plate and spread them around. Use multiple plates if the smells are extreme.Place the plate on the center shelf.Close the refrigerator for 24 to 48 hours.Dispose of the coffee grounds.
  5. Cut a lemon in half and put it in there - it will absorb the smells and make it clean smelling.
  6. Last but not least ....Empty contents of fridge wipe out with warm water and a little lemon juice then cover a tray or plate with kitchen foil and fill with charcoal put in fridge over night and the charcoal absorb es all nasty ouders then in morning remove plate or tray.It should have no smells at all.
Thank you for this opportunity t post few tips which i know. I think all the above are home made tips and anyone can try it out who are facing the problem of bad odor in their refrigerator..
on Oct 18, 2009 | Kenmore 50522 / 50524 Side by Side...
Bad smell in washing machine
Try using this cleaner on the washer. It works great!!
Jun 26, 2013 | Washing Machines
Daewoo american fridge freezer bad smell
look up the fridge on line or check the manual how the freezer is build. some freezers have a small space under the bottom of what you see as the bottom, where liquids can be trapped and haunt you for ever if you done lift the bottom part up and get under it. good luck
Jan 27, 2018 | Daewoo Refrigerators
Problem is rotten smell inside GE profile fridge. I've checked for rotten food-none; taken everything out and cleaned inside plus all shelves with added bleach in water. Smell is still there. I...
Hi, pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. You can also mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section. Too much bleach and the smell of bleach would be circulated by the fan to the room, so be sure to add water. Finally, another popular methods of removing fridge odor include washing the entire fridge out with a vinegar and water solution, placing fresh coffee grinds or boxes of baking soda on each shelf and even using trays of cat litter.
May 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My fridge did not reset itself after a power outage over Christmas so I came home to a fridge of spoiled meat. I have cleaned everything but I am wondering if there is a drip pan or something that I need...
The evaporator tray is inside the bottom "kickplate". It is formed of flimsy plastic and must be lifted out carefully to avoid dumping contents. Dump it in the sink for subsequent scrubbing clean. Also, check the drainage tube in the bottom rear of the freezer compartment for clogging. It will have to be reamed (with a chopstick) and flushed to remove residue. Be sure to have the plastic tray back in place to catch drainage from the flushing operation and repeat the tray cleaning operation.
One final thing: Put an open box of bicarbonate of soda inside the refrigerator section to absorb residual odor. Good luck!
Dec 16, 2017 | LG (LRBC22522ST) Stainless Steel
Strong musty damp smell - tried soda crystals, vinegar etc and nothing shifts it. any ideas?
Try a full bag of soda crystals on a hot wash...and then add them regulalrly. They are not a deodoriser but will help clear the gunk that is causing the smell. Bicarbonate of soda is a better deodoriser though.
Mar 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bad Smell
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Aug 31, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Neff K5624X0 1GB Refrigerator Logo
287 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
