Question about Vivitar ViviCam 6330s Digital Camera
Installing the USB Driver
When inserting the cd and trying to install the USB Driver it keeps telling you that "you do not have access to make the required system configuration modifications. Please re run this instillation from an administrators account". Please advice.
  • 10,594 Answers
While starting computer having Windows-XP O.S, you should login as administrator, so you can install software.
Posted on Jun 01, 2008
Problems installing printer Samsung 315 clp to laptop windows7
Do the following:
1. Insert the CD/DVD that comes with the printer into the cd/dvd drive in the laptop.
2. If you do not have CD/DVD then download the driver/software from Samsung website.
3. The software should start installing. If not find setup.exe and double-click it.
4. During the installation it will ask to connect the printer. Then plug the printer to the wall socket and turn it on. And insert the USB cable into the printer USB port as well as into Laptop USB port.
5. The printer will be detected automatically and necessary driver will be installed.
6. Wait for the installation to finish. Now you can use the printer and print document and photos.
Aug 09, 2011 | Computers & Internet
How to install usb data cable
A USB cable driver is need to be installed for the USB cable to work and this driver comes with the cable itself. insert the cd, let the wizard open, click on install and follow the steps or after the wizard is open, click on the option for installing driver for USB cable. Enjoy !!! Thanks for using fixya !!!
Nov 11, 2010 | Nokia 7210
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
I have problem with my drivers
Problem 1:-Where to find the driver?
Driver can be found out inside the motherboard.In motherboard chip set you will found out by the writing image written on left or right of display,sound,USB,cards.
Problem 2:-Problem according to installing.
If you have driver disc but you can not or have not experience to installing.Do not worry,insert your CD in the CD drive,you will seen the dialogue box that which driver you have to install.Select driver to install in your computer.Follow instructions to install,
Problem 3:-You have installed driver but it does not work properly.
For this issue you have to join with your hardware components.For this, remove your certain driver card which are not worked and re-enter it into expansion slot.
If these three problem will not match with your one then tell me what actual problem is running in your PC.
Apr 22, 2010 | Intel Motherboard
I recently installed a new hard drive and as I was installing the windows vista home basic I keep getting a message that says the computer restarted unexpectedly or encountered an unexpected error. Windows...
Hello
Thank you for using FixYa for your problem
Is the old HDD still installed, maybe the new drive is faulty, or the Install disc is scratched or dirty
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 22, 2009 | Computers & Internet
Installing usb cable without cd
you can not install the cable it is the device atteched with the cable that gets installed.to install a usb device with out cd insert cable into device and then the computer.you should see a small window that says :new device found: then installing device then:
installation failed no drivers found etc...now at this point you tell the computer to search online for appropriate drivers. if this doesnt't work write me and tell me what the device is and i'll help you find appropriate drivers
Apr 23, 2009 | Computers & Internet
Trying to help my sister to install her ginius webcam, but it is not working. She installed the software driver but can't get cam to work. Anyone out there with same problem that could give us a hint will...
1. Please install the driver first and then connect VideoCAM Trek to the USB port.
2. Installing the VideoCAM Trek driver
Windows Environment
a. Insert the VideoCAM Trek Installation CD into the CD-ROM drive.
b. The Autorun screen will bring up the installation screen. Click on
Driver” then simply follow the on-screen instructions.
c. Install DirectX from the CD.
Notice: If the Autorun screen doesn’t start, please follow these
steps:
�� Click on “Start Menu”
�� Type D��\SETUP.EXE , then click Enter key.
(Assume your CD-ROM is in Drive D)
Mac Environment
drive.
b. Double click on the CD-ROM driveglish
c. Click on the file folder of “VideoCAm Trek Driver OSX 1.0
d. Click on “VideoCAM Trek Driver Install” then simply
3. Insert the VideoCAM Trek’s USB cable to your desktop’s or
laptop’s USB port.
4. Complete software and hardware installation. You can
install the software you would like to use for video
conferencing or chat with your friends.
Hope this helps! Let me know how you make out with it!
Apr 04, 2009 | Genius VideoCAM Trek Webcam
Dell server
1) it may just be a driver issue. look up the control panel / devices. if you see a yellow marker , then the drive is at fault . find the driver and install, then try again.
2) maybe the cdrom is dead , try change to another one.
3) if you dont have spare , plug in an external usb cdrom drive . this way , you can still do the update. many dell laptops use external usb cdrom.
Regards
David Ng
Nov 04, 2008 | Dell PowerEdge 6300 Server
Driver
try with reinstalling usb driver by your mother board cd,and install chipset INF,
check in other pc to check weather your pendrive got faulty
regards
prasanna
Mar 08, 2008 | Electronics - Others
Vivitar ViviCam 6330s Digital Camera Logo
69 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
