Question about Amana Kitchen Ranges
Maytag Amana Range Easy Touch Control 500 - Gas
Maytag Amana Range Easy Touch Control 500 - Gas Model #AGR5715QDW Ideally looking for LP to NG conversion instructions, but would be thrilled with factory NG to LP conversion instructions. Purchased use and is currently converted to LP. I need to convert it back to NG. Installation instructions state an LP Conversion Kit and instructions came (new) attached to back of range, but there is no saved NG hardware or the LP conversion instructions with range now. Knowing that it came new with a LP Conversion Kit makes me assume more than just the Pressure Regulator orifice needs to be changed out. I surely wish I had those instructions, as they would show all that needed to do in reverse (from LP back to NG). That brings me to my questions. On this model (#AGR5715QDW) what all has to be done to convert LP to NG? I am knowledgeable of basic (old) converting, but want to make sure I cover all bases correctly with this model. Pressure regulator – done by switching orifice to NG. Bake burner – orifice change, shutter adjustment or both? Broil burner – orifice change, shutter adjustment or both? Surface burners – orifice/stub change, shutter adjustment or both? Does anything else need changed out or adjusted? Any information would be greatly appreciated! Thank you, Jamie
5 Suggested Answers
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
SOURCE: Frigidaire Gas Range GLGFS75DBA
If you didn't keep the original orfices for natural then you need too buy the burner orfices seperatly, and the oven regulator just needs adjusted you can go the frigidaires web site and download the installation instructions for the proper settings.
Posted on Jul 30, 2008
SOURCE: Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Posted on Jan 05, 2009
SOURCE: I converted my 40
I am having almost the same problem. Frigidaire told me to replace all 5 mixing tubes, ~$385, yeah right. They don't have the orifices itemized as an individual part, so no-one carries them, just the LP conversion kit. Another repair/parts guy advised me to drill out the orifices. Some other threads/blogs give the diameter to drill. Basically, since natural gas is 0.5 psi, you need a larger hole than your current propane orifices provide. Please speak up if you find out anything, I will try to do the same. Good luck.
Posted on Nov 25, 2009
Manual
When the range top burners and the oven are both not lighting, I recommend you check if the manual shut-off valve to the range has been turned off. With most of my gas ranges, you have to remove the drawer to reach the shut-off valve. (so If you have propane, make sure that your tank isn't low.
Make sure that your home is well ventilated; open the windows and check the range in a while. I live in an area where we had to add a whole house ventilator. We had days where the house would seem stuffy and none of the burners would light. (Appliances with pilot lights went out.) This was due to excess carbon dioxide shifting from nearby coal and natural gas deposits.
It is possible for the igniters to fail if there is power to the range, but usually not the oven, the broiler and all of the top burners at once. You can test the top burners carefully with a long handled butane lighter or a long match. Turn on the hood fan and set a burner to the Lite position. Carefully, light the lighter near the burner or bring the lit match to the burner. If the gas is flowing properly and there is sufficient oxygen, it should light. Then remove the lighter or match and put it out. Then adjust the burner temperature.
The manual for the ARGS7650SS is available from Amana. The direct link is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/31810401.PDF . Many newer Amana product manuals are available here: http://shop.amana.com/product_literature/search.jsp .
I hope this helps.
(note: you should also make sure that the regulator cap is correctly set for your type of gas (LP or NG). The gas flow rates are different enough to make the regulator fail. Most ranges are shipped for with the cap set for NG. Turn off the gas and unplug the electrical cord before working on the regulator cap. The burner orifices need to be changed as well as some other adjustments to convert from NG to LP. See pages 9-11 of the manual for details.)
Jun 26, 2013 | Amana ARGS7650SS Gas Kitchen Range
I have an amana gas range easy touch control 500. the oven will not light every thing else is working fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | Amana Ovens
IWANT TO CONVERT TO PROPANE
It's probably not quite as easy as everyone says. Most gas appliances use a different control valve for LP (propane) and natural gas. You most likely will have to eplace the control valve with an LP one. I would contact Amana to see if they offer a conversion kit -- it would probably come with detailed instructions.
Nov 17, 2009 | Amana ACS3350 Gas Kitchen Range
We have same range and are looking to convert from LP to NG
Hi some models will not convert to lp to nat gas , matbe you can sell it or do a swap with some one not much help sorry
Aug 12, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I cannot seem to get an answer from Amana as to how I convert my natural gas range to LP. According to Amana no conversion kit is needed. Yet they cannot tell me how to convert it. The model number is:...
Gas ranges usually come with LP orifices attatched to them somewhere. In a small envelope or bag taped to the back or in the drawer they should be there. The natural orifices need to be removed and the LP ones installed. If the LP orifices are not installed properly you may get irratic flame and the flame can blacken the bottom of pans this needs to be remedied immediately due to the danger of the carbon monoxide being produced. I found good instructions for LP conversion at this site : www.peerlesspremier.com/faq-rangeconversion.htm
Dec 24, 2008 | Amana AGR5735QDS Gas Kitchen Range
Thermador PG484GGBS: How to convert from Natural Gas to LP?
I just did it with mine, I called thermador and they told me the number of the conversion kit to buy for my model.
I bought the kit from the retailer and did it myself, not very difficult.
no explosions yet :)
nic
Dec 25, 2007 | Thermador PG484GGEBS Stainless Steel...
Kitchen Ranges Logo
137 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
