Question about Cameras
When I place my sony cybershot's charged infolithium battery back in my camera, it works for about 5 seconds, then the screen goes black, and the words "infolithium battery only flash", along with an empty battery with a diagnal line through it, then shut off. this has never happened before.
  • 10,594 Answers
Camera is not getting Info Signal from battery so it gives error.
One solution is to deattache the battery for couple of hours and try again.
2nd is that camera has hardware problem though its not big and requires qualified technician.
Posted on Jun 01, 2008
Use infolithium battery pack
I believe Shahid is correct... it's probably the pins.. try this... first make sure all switches are off during the entire process (viewfinder pushed in and keeping the LCD closed, try cleaning the pins on the back of the camera with a Q-Tip and Isopropyl alcohol (91% if possible)... leave it a bit damp and push the battery into place several times to clean it's contacts too.. then let everything dry, reconnect the battery and turn it on. The problem will hopefully be all gone.
Apr 29, 2012 | Sony Video Cameras
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jul 25, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
I keep getting the message: Turn the power off and on again. Just bought the Cybershot DSC-W370 tonight and it worked fine, until the battery was charged. ???
Why don't remove the battery? First, switch off the camera then remove the battery. Wait for 5-10 mins then put the battery back on and charge it straightaway. remember to leave the camera off while charging. let it charge full then unplug and switch the camera back on. let me know if this works for you.
Jun 26, 2010 | Sony Cybershot DSCW370 Digital Camera
For Info Lithium Battery only
I was having the same problem with a sony GV-D1000 which I don't even use a battery with. I use an AC adapter. Someone suggested that the contacts might be dirty, so I unplugged the small connector that plugs into the back of the deck and wiped it hard with my t-shirt. It seems to work fine now. SO try cleaning the contacts (wherever your adapter or battery connects with the deck or camera.)
Aug 11, 2008 | Sony GV-D1000 Mini DV VCR
When I place my infolithium battery into my Sony Cybershot camera, it doesn't work. It works for about 5 seconds, and then the words: infolithium battery only flash and the screen goes black and the...
Camera doesn't get Info Signal from battery thats why gives such message. One solution is to deattache battery for couple of hours and try again.
2nd is that camera has hardware problem and requires qualified technician to repair it though its not big repair.
Jun 01, 2008 | Cameras
Im going crazy with this thing!!!!
try energizer lithium batterys-non sony rechargable don't work in most sony cameras
May 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony Cybershot S700 black screen when USB cable is inserted.
try going into the menu and doing a camera reset this corrects alot of connection issues. hope this helps.
Mar 02, 2008 | Sony Cybershot S650 Digital Camera
Cameras Logo
207 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
