Question about HP Photosmart 3210 Printer
I have an HP Photosmart 3210 All-in-One (Printer-Scanner-Copier) and it recently has decided to stop scanning and copying. I have never had problems prior to this; and have tried disconnecting and powering down several times. Why is it not working??
  • HP Master
  • 1,679 Answers
We are not sure what could be the cause of this issue. There is a simple method to fix this issue
Click on the link below to download and run the HP scan diagnostic utility.
This utility will diagnose the issue and try to fix it as well.
Click on the link to download the utility program - Link
Posted on Oct 12, 2010
Printer HP Photosmart 3210 will not work
I put item to be copied on the copier glass. I press copy. On copy menu I press number of copies. I press OK I press color start button. The copier starts to work and then a message apprears on the copy screen ' UNABLE TO SCAN " and the command is aborted. I have tried checking drivers and they are okay.
Apr 13, 2011 | HP Photosmart 3210 All-In-One InkJet...
Problem with all in one not doing the fax, scanner or downloading
Hi Jan,
I would like to know the answers for the below question. Please reply back.
What is the error that you get while scan?
how is the printer fax part is connected?
Are you able to print from computer?
What is the operating system of your computer?
Regards
Riztech
Jun 04, 2010 | HP Photosmart 3210 Printer
Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
Printer not communicating with computer
Try go to system prefs, print and fax. Remove your printer from list then add it again. It may pay to uninstall software first, then reinstall
Apr 29, 2009 | HP Photosmart 3210 Printer
HP 7180 ALL IN ONE WON'T PRINT
Take it back. It's under warranty. Check scanner is not good
Mar 10, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Mar 04, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210xi Scanning Issue
no scan options refer to device documentation to troubleshoot
Jul 12, 2008 | HP Photosmart 3210 All-In-One InkJet...
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47754-1&lc=en&cc=us&dlc=en&product=439488&os=2093
Check to make sure you don't have "HP Director" under your start menu. The link above has the full package of windows vista drivers, which includes the scanner drivers.
Apr 12, 2008 | HP Photosmart 3210 Printer
HP Photosmart 3210 All-In-One printer copier scanner
hi,
try this
> uplug the usb cable
> insert the cd which came along with the printer
> open the folder "util-->ccc" in the cd rom drive
> locate a file called "uninstall_l3"
> a black screen would be popped up. go on with the instructions.
this will uninstall all the hp softwares related to this printer from your computer even from the registry.
once that is done
> take out the cd and insert it once again
> click the install button on the screen which will pop up.
> when the software asks you to conect the printer, plug the usb cable back.
thats it.... try to make a scan. if it is still not working proceed to the following steps.
> unplug the power chord from the printer while it is turned on
> press and hold # and 3 button on the printer at the same time.
> while holding it, insert the power chord and wait for 5 seconds.
> release your hands
> when it is done, try to make a scan.
still not working????
you may have to service the unit.
thanks and regards
agnel
Jan 22, 2008 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
103 people viewed this question
Seeker5211
Seeker5211
