Question about Sport & Outdoor - Others
Hello - I have a Troy-Bilt 5524 snow thrower. Getting ready for this winter, and the wheels are locked (when you press down the drive handle, no movement despite engagement of the friction wheel. I took off the plate, and looked, and it seems to be something with the hexagonal drive shaft. When I remove fastener, and move the small gear to the left, the snow thrower moves freely. Put this gear back in place - frozen again... hmm. I found a post on another site that said something about "frozen / rusted needle bearings on a drive shaft". But don't know what that means. Any help you could provide would be appreciated! Thanks, Randy Swenson
  • 78 Answers
SOURCE: my poulan snow blower keeps breaking sheer pins in the wheels,
1)try replacing them with a heavy duty "roll-pin"
these are available from auto parts stores.
two types are available.
first is the "single-roll",second is the"multi-rolled"with many layers to it.
try both they're cheap.
2)try not hitting things with the blades
3)dont force the machine in heavy wet ,or frozen icy packed snow.
Posted on Dec 23, 2008
  • 2976 Answers
SOURCE: SNOW BLOWER FRICTION WHEEL WON'T DISENGAGE
Use a good quality silicon lube and spray into the top of the cable. Do this until it comes out the bottom, a little at a time. Also, spray all pivot points. Don't use WD-40, it will freeze. Lube everything at the end of winter and again before winter.
Posted on Jan 31, 2009
  • 181 Answers
SOURCE: bicycle handlebars move seperatly from the wheel
most older bicycles have a bolt running straight through the handlebars.in the middle of the handlebars is there a allen key head or a single 10 mm nut head, depending on the bicycle you have. some have four screws holding a bracket on ,theses have notches to stop the bars from going up and down. look under the plate to see if there is any way of tightening the bars up. hope this helps
Posted on May 12, 2009
SOURCE: craftsman snow blower wheels wont move. Help!
If it is a 5.5 HP dual stage, like mine, it could be that the belt has popped off the friction pulley. If you drain the gas, tip the unit on its "face" and remove the large shield on the bottom you will see a 3" pulley attached to the drive shaft. There will also be what looks like a fan belt floating around in there. That fan belt nees to go on the pullet, as it serves as the friction disk tio drive the wheels. Good luck. this happens to mine ALL the time. very frustrating. :(
Posted on Feb 13, 2010
  • 3 Answers
SOURCE: weight wheel moved from 25 to 30 while outside of
Push button under on the bottom of the handle to release the adjuster. If it was moved while out of the little stand it may be damaged or not working well. If it was a fluke, just push the button take all the weights off both sides and start over on 5. That button should normally only be depressed when the handle is seated in the stand.
Posted on Mar 30, 2010
How do I replace Blower Bearing?
Strip down, remove shaft, push out seals and then bearings. Take bearing and seals to a bearing supplier and they will replace by the part number on the bearing. Refit will plenty of lubricant.
Mar 04, 2016 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Have a troy bilt 10030 snow thrower and there is slack in the drive chain on the left wheel were shaft come thru the bolt
many blowers have slots instead of holes on that shaft to take up the slack. look at the hardware where the shafts pass thru the chassis.
Nov 09, 2015 | Garden
Chute on Troy Bilt single stage snow thrower won't turn
CHECK TO SEE IF THE ICE FROZE I THE CHUTE YOU MAY HAVE TO PULL THE COVER OFF THE TOP THIS SOUNDS LIKE THERE MIGHT BE ICE BUILD UP ALSO AFTER THE COVER IS PULLED OFF CHECK THE GEAR THAT TURNS THE CHUTE BY TURNING THE HANDLE
Feb 26, 2015 | Troy-Bilt Squall 2100 208 cc 21-in...
Troybilt snow thrower wheels lock up cannot push or pull. Model 5524. Whats up?
Sounds like friction disk is not retracting for pressure plate. Flip snowblower up on front end and take out 4 or 6 bolt out of cover plate. wheels will be in the air so try to turn wheels and look. Your fiction disk is the rubber wheel that moves with you gear shift lever. It should not be touching round metal plate unless your handle on bars is push down to in gage drive. Most snowblowers have a spring to pull metal plate back your probably broke or rusted off.
Feb 24, 2015 | Garden
Troy bilt 5524 snow blower with no spark
check kill system... there is a safety switch close to the auger or the cover for it... then suspect a coil but next time, how about mentioning the engine because troy bilt never doesn't make engines
Aug 24, 2014 | Garden
Troy bilt repair manual
Check with the engine manufacturer if you have trouble with Troy built.
Aug 03, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Troy bilt fix
check drive belt
tip it on its nose, ( be sure gas is only 1/2 full or less)
remove plate on the bottom
see if wheel is close to the alum plate
sqeeze handle see if wheel contacts plate
if not adjust cable under handle
Mar 31, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Troy-bilt 5524 snowblower - the drive wheels are locked. Pulled it apart and everything turns but when all gears are in place wheels won't turn - If I move the small gear from the drive it works but goes...
The outermost large gear has 'needle' bearings that will over time get snow, salt grim caught in them and they freeze up. Remove the gear and intially work some WD-40 into the bearings with your fingers. Mine loosed up fairly easy. Continue adding WD-40 to kind of rinse away the grim. Then, dry it out with a rag. I added some lithium (white) grease and worked it good before replacing. Once replaced, it will spin like a top!
Oct 31, 2010 | Kitchen Ranges
Sport & Outdoor - Others Logo
35 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
